1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer programs in an IOC
To: <[email protected]>
Date: Wed, 23 Jan 2013 15:54:09 +0100
On Tuesday, January 22, 2013 15:31:02 James F Ross wrote:
> It seems to be going running the program relating to the
> eemc (one of the early ones called by a seq command in the st.cmd file) but
> never moves on to the program after it.  There is no indication of error,
> but I'm looking at both the eemc source code and the bemc code (the next
> program called in the st.cmd file).
Which release of seq are you using? This sounds a bit like a known problem
with one of the earlier releases in the 2.1 series (see http://www-
csr.bessy.de/control/SoftDist/sequencer/KnownProblems.html#known-problems-in-
release-2-1-6).
When building, check that whenever snc is executed it does *not* have the '-i'
switch passed. If it does, search your Makefiles and remove '-i' from SNCFLAGS
definitions.
If you are using a release later than 2.1.6 this does not apply.
Instead of checking all PVs you programm variables are assigned to (as has
been suggested), you could play around with the -c flag to snc, at least to
make sure that missing PVs are really the cause of your problem (with -c the
programs start w/o waiting for connections; this may mean they will not work
correctly but at least you should see them running with seqShow).
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
sequencer programs in an IOC James F Ross
RE: sequencer programs in an IOC Mark Rivers
Re: sequencer programs in an IOC James F Ross
Prev: RE: DXP ElapsedRealTime Mark Rivers
Next: Re: sequencer programs in an IOC Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer programs in an IOC James F Ross
Next: Edm installation Steve
