To suppress the comma for 1,000's:
In java.text.NumberFormat;
I need to specify setgroupingused(false) for that value. So, this I
cannot change in the Basic_EPICS package I downloaded from SNS.
-ps
On Fri, Jan 25, 2013 at 6:00 PM, Paul Sichta <[email protected]> wrote:
> Exploring BOY-land from medm.
> 1) Using BOY, I want large numbers to be displayed with no comma.
> e.g. 145,123 I want to display as 145123
> Widget type text update, format type decimal. Tried format string and
> that showed gibberish. Also tried a few others widget types to no
> avail. I tried several LC_NUMERIC environment settings before css
> launch, no help there.
> Any ideas?
> 2) With medm, when I resized a display's window the entire display
> scaled. With BOY this is not the behavior - you just shrink the
> visible portion of the display. To shrink/enlarge/scale the entire
> display takes several steps and the F8 key. Is there a trick or
> setting to rescale the entire display - widgets, text, objects? Does
> a WebOPI display behave any differently in this regard?
> just some comments on my experience:
> Had success with SNS Basic_EPICS version.
> I was very impressed with how quickly I was able to adl2boy our 400
> medm displays. Most needed a tweak (compound visibility rule) and
> some wouldn't convert (shell script launcher?) but basically they all
> worked. adl2boy worked on my 32-bit RHEL5 Basic_EPICS but not on my
> 64-bit RHEL_5.
> I like the tabbing feature when additional displays are brought up,
> but I also like to arrange many displays across numerous operator
> screens - often shrinking the displays to get more on there all
> visible at once. I added an action button to each display to 'detach'
> ; that gets me my displays on independent windows. I tried to drag
> the display's tab out of the window but this didn't work. I also
> thought a right-click option to 'detach' would also be useful ...I
> know I know, if I want that feature then code it up :). But my
> window resize/rescale issue remains. The operators are used to this
> feature.
> -ps
- BOY number representation & display scaling Paul Sichta
Re: copying archived data from 32-bit to 64-bit machine James F Ross
Re: copying archived data from 32-bit to 64-bit machine Pierrick Hanlet
<2013>
2025
2026
RE: BOY number representation & display scaling Kasemir, Kay
RE: BOY number representation & display scaling Chen, Xihui
<2013>
2025
2026
