1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Save/Compare/Restore Application
To: "Shen, Guobao" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 30 Jan 2013 09:51:49 -0800
Guabao,
SCORE is Java based and here we are using .... python (as well as Qt, pyqt, SQLlite, and Fedora 16)!
So our preference go to MASAR, but....
I looked at the documentation and noticed some interesting features.
Assuming I have a signal with white noise that is captured in a ai record,
if I compare its current and previously saved value, there are likely to be different.
Is there a way to say that for that PV, if the value is within 3 standard dev (configurable per PV) then do not report the PV as different?
Are the sources MASAR available?
Is this software packaged and ready to be distributed?
If so, where is a download page?
Emmanuel
To: [email protected]
Subject: Re: Save/Compare/Restore Application
Date: Wed, 30 Jan 2013 03:27:00 +0000
CC: [email protected]
Hi Emmanuel,
Here at NSLS II, we have developed a tool for this purpose, which I named it MASAR, and are using it for our beam commissioning.
It is capable to take a snapshot with any pv combination, for example with scalar pv and waveform pv.
An online user manual can be found at
There are sections to explain how to compile everything from source, and run a demo.
I have all binary packages against Debian 7. If you want them, I can send to you.
Guobao
On Jan 29, 2013, at 8:00 PM, "Emmanuel Mayssat" <[email protected]> wrote:
Hello,
I am exploring save/compare/restore applications out there as I intend to replace ours.
To date, I am only aware of SCORE used at ORNL.
Is anyone on this mailing list maintaining/developing/administrating SCORE?
Is anybody using something else? If so, what? Is there a project web page?
Emmanuel
RE: Save/Compare/Restore Application Emmanuel Mayssat
Re: Save/Compare/Restore Application Shen, Guobao
Prev: CSS addr_list bug Paul Sichta
Next: RE: Save/Compare/Restore Application Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Save/Compare/Restore Application Shen, Guobao
