Guabao, I found the mercurial repository (although for some reason I cannot access it, but that maybe on my side) Is EPICS V4 required? I have an EPICS V3.14.11 installation.... -- E
From: [email protected]To: [email protected]; [email protected]Subject: RE: Save/Compare/Restore Application Date: Wed, 30 Jan 2013 09:51:49 -0800 CC: [email protected]
Guabao, SCORE is Java based and here we are using .... python (as well as Qt, pyqt, SQLlite, and Fedora 16)! So our preference go to MASAR, but....
I looked at the documentation and noticed some interesting features. Assuming I have a signal with white noise that is captured in a ai record, if I compare its current and previously saved value, there are likely to be different. Is there a way to say that for that PV, if the value is within 3 standard dev (configurable per PV) then do not report the PV as different?
Are the sources MASAR available? Is this software packaged and ready to be distributed? If so, where is a download page?
Regards, -- Emmanuel
From: [email protected]To: [email protected]Subject: Re: Save/Compare/Restore Application Date: Wed, 30 Jan 2013 03:27:00 +0000 CC: [email protected]
Hi Emmanuel,
Here at NSLS II, we have developed a tool for this purpose, which I named it MASAR, and are using it for our beam commissioning.
It is capable to take a snapshot with any pv combination, for example with scalar pv and waveform pv.
An online user manual can be found at
There are sections to explain how to compile everything from source, and run a demo.
I have all binary packages against Debian 7. If you want them, I can send to you.
Guobao
Hello,
I am exploring save/compare/restore applications out there as I intend to replace ours.
To date, I am only aware of SCORE used at ORNL.
Is anyone on this mailing list maintaining/developing/administrating SCORE?
Is anybody using something else? If so, what? Is there a project web page?
Emmanuel
- Re: Save/Compare/Restore Application Shen, Guobao
- Save/Compare/Restore Application Emmanuel Mayssat
- RE: Save/Compare/Restore Application Emmanuel Mayssat
Job Openings at APS Nicholas Schwarz
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
