1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Portable Channel Access C++
To: [email protected]
Cc: Bruno Santos <[email protected]>
Date: Thu, 7 Feb 2013 11:19:14 -0600
Hi Bruno,
On 2013-02-07 Bruno Santos wrote:
> Does anyone have any portable channel access examples in C++?
> How I can get the last version of pcas c++?
The PCAS is provided as part of EPICS Base (under src/cas); the latest version
is the one that was shipped with the recent Base 3.14.12.3 release, which
added support for DBE_PROPERTY events (caServer::propertyEventMask()).
Once you have that installed you can use the makeBaseApp.pl script to create
an instance of the caServer template which provides a couple of example server
programs. Others here should be able to point you to some more complex
examples if you want them.
HTH,
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Portable Channel Access C++ Bruno Santos
Prev: Portable Channel Access C++ Bruno Santos
Next: Re: [CSS] the tab widget's active tab Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: support module for Xspress 3 matthew.pearson
