1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AsynInt32 device support and mbbo records
To: Florian Feldbauer <[email protected]>
Date: Fri, 15 Feb 2013 10:38:42 +0100
Hi Florian,
yes, you have to set also the values. The numbering scheme distinguishes between sixteen states,
but their value does not have to be 0, 1, 2, 4..., but could be anything.
Burkhard
Dr. Burkhard Kolb
Tel +49 6159 712667
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker, Peter Hassenbach
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Am 15.02.2013 um 10:14 schrieb Florian Feldbauer:
> Hey,
> I have written an AsynPortDriver for the TMCM142 1 axis stepper driver/controller
> The motor driver is connected via CAN bus and expects a message with 7 bytes of data:
> byte 0: command number
> byte 1: parameter number (I'm using the addr parameter from the asyn interface)
> byte 2: motor number (only one motor can be connected to the driver so it is always 0)
> byte 3-6: data (32 bit signed int)
> For setting the microstep resolution of the motor driver the data has to be a number between
> 0 and 11, each coding a different resoultion.
> I wanted to use a mbbo record, which looks like this:
> record( mbbo, "PANDA:$(subsys):MOTOR:$(SECTOR):SAP:USTEPRESOLUTION" ) {
>  field( DTYP, "asynUInt32" )
>  field( OUT,  "@asyn($(BUS),27,1)TMCM142_SAP" )
>  field( ZRST, "2048 micro steps" )
>  field( ONST, "1024 micro steps" )
>  field( TWST, "512 micro steps" )
>  field( THST, "256 micro steps" )
>  field( FRST, "128 micro steps" )
>  field( FVST, "64 micro steps" )
>  field( SXST, "32 micro steps" )
>  field( SVST, "16 micro steps" )
>  field( EIST, "8 micro steps" )
>  field( NIST, "4 micro steps" )
>  field( TEST, "2 micro steps" )
>  field( ELST, "1 micro steps" )
> Unfortunately, the value inside my writeInt32 function from the asynPortDriver is always 0.
> Do I have to set the ZRVL,...,ELVL fields for asynInt32? Or do I need another asyn interface for
> this record?
> Best regards,
> Florian
> | Dr. Florian Feldbauer                |
> | Helmholtz-Institut Mainz /           |
> | Johannes Gutenberg-Universität Mainz |
> | Johann-Joachim-Becher-Weg 45         |
> | D-55128 Mainz                        |
> | Office: 01/217                       |
> | Phone:  (+49)6131 / 39-25829         |
Re: AsynInt32 device support and mbbo records Ralph Lange
AsynInt32 device support and mbbo records Florian Feldbauer
Prev: AsynInt32 device support and mbbo records Florian Feldbauer
Next: Re: record info field in which epics version? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: AsynInt32 device support and mbbo records Ralph Lange
