Subject: |
Re: AsynInt32 device support and mbbo records |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 15 Feb 2013 11:27:32 +0100 |
For 3.15:
Should we change the record support to use the index (option number) if
and only if all ..VL fields are zero?
This would even match the regular soft support behavior that writes the
index value.
I can't imagine someone relying on device support always being called
with zero, no matter which state the record is in.
~Ralph
On 02/15/2013 10:38 AM, Burkhard Kolb wrote:
> Hi Florian,
> yes, you have to set also the values. The numbering scheme distinguishes between sixteen states,
> but their value does not have to be 0, 1, 2, 4..., but could be anything.
> Burkhard
> Dr. Burkhard Kolb
> Tel +49 6159 712667
> GSI Helmholtzzentrum für Schwerionenforschung GmbH
> Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
> Gesellschaft mit beschränkter Haftung
> Sitz der Gesellschaft: Darmstadt
> Handelsregister: Amtsgericht Darmstadt, HRB 1528
> Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker, Peter Hassenbach
> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
> Am 15.02.2013 um 10:14 schrieb Florian Feldbauer:
>> Hey,
>> I have written an AsynPortDriver for the TMCM142 1 axis stepper driver/controller
>> The motor driver is connected via CAN bus and expects a message with 7 bytes of data:
>> byte 0: command number
>> byte 1: parameter number (I'm using the addr parameter from the asyn interface)
>> byte 2: motor number (only one motor can be connected to the driver so it is always 0)
>> byte 3-6: data (32 bit signed int)
>> For setting the microstep resolution of the motor driver the data has to be a number between
>> 0 and 11, each coding a different resoultion.
>> I wanted to use a mbbo record, which looks like this:
>> record( mbbo, "PANDA:$(subsys):MOTOR:$(SECTOR):SAP:USTEPRESOLUTION" ) {
>> field( DTYP, "asynUInt32" )
>> field( OUT, "@asyn($(BUS),27,1)TMCM142_SAP" )
>> field( ZRST, "2048 micro steps" )
>> field( ONST, "1024 micro steps" )
>> field( TWST, "512 micro steps" )
>> field( THST, "256 micro steps" )
>> field( FRST, "128 micro steps" )
>> field( FVST, "64 micro steps" )
>> field( SXST, "32 micro steps" )
>> field( SVST, "16 micro steps" )
>> field( EIST, "8 micro steps" )
>> field( NIST, "4 micro steps" )
>> field( TEST, "2 micro steps" )
>> field( ELST, "1 micro steps" )
>> Unfortunately, the value inside my writeInt32 function from the asynPortDriver is always 0.
>> Do I have to set the ZRVL,...,ELVL fields for asynInt32? Or do I need another asyn interface for
>> this record?
>> Best regards,
>> Florian
>> | Dr. Florian Feldbauer |
>> | Helmholtz-Institut Mainz / |
>> | Johannes Gutenberg-Universität Mainz |
>> | Johann-Joachim-Becher-Weg 45 |
>> | D-55128 Mainz |
>> | Office: 01/217 |
>> | Phone: (+49)6131 / 39-25829 |
- Re: AsynInt32 device support and mbbo records Hu, Yong
- AsynInt32 device support and mbbo records Florian Feldbauer
- Re: AsynInt32 device support and mbbo records Burkhard Kolb
Re: record info field in which epics version? Ralph Lange
New version of LabVIEW-EPICS-interface CA Lab 1.4.1.0 Carsten Winkler
<2013>
2025
2026
<2013>
2025
2026
