1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New version of LabVIEW-EPICS-interface CA Lab 1.4.1.0
To: tech-talk <[email protected]>
Date: Fri, 15 Feb 2013 13:49:59 +0100
We are happy to bring you the improved version of our
LabVIEW-EPICS-interface CA Lab 1.4.1.0!
http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Change-log of CA Lab
V1.4.1.0 (Released: February 2013)
  + New memory management
  + Gaps in string arrays are possible now; e.g. ['a', 'b', '', 'd']
    (EPICS data type must be a string array!)
  + New LabVIEW control "PV Info" (output cluster),
    project "CaLabs.lvproj" and aliases "CaLabs.aliases"
    (Thanks to Robert M. Everly)
  + Global Channel Access warnings and errors are displayed
    via "Debugging window" of LabVIEW
  # Just one call of caLab.dll in caLabGet.vi instead of two
  # Parallel running instances of CA Lab don't freeze anymore
  # Events: Initially disconnected variables receive values
    after connection is established (fix)
  # Improved LabVIEW convention of VIs
  # Update of ReadMeFirst.txt
  # Delayed termination of VIs if they run a very short time (<10sec.)
    This guarantees a safe termination of EPICS environment.
  # Write values (without synchronous) is up to 10 times faster now
  # Read values is up to 5 times faster now
  - Removed buffer size (since version 1.3 without function)
  - Removed dead lock detecting and auto unfreezing
    (No workaround needed anymore)
*** Note ***
If you upgrade existing VIs with CA Lab please exchange:
    caLabGetxx.vi -> caLabGet.vi
    caLabPutxx.vi -> caLabPut.vi
and click right on greyed out CA Lab VIs and use "Relink to SubVI"
to update type of Polymorphic VI.
Watch out! LabVIEW may result in a misalignment of connectors!!
All suggestions and comments are welcome!
Cheers
Carsten
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: Re: AsynInt32 device support and mbbo records Ralph Lange
Next: RE: AsynInt32 device support and mbbo records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: AsynInt32 device support and mbbo records Mark Rivers
Next: Has anyone converted AllenBradley (scanner) driver and device support to EPICS OSI? Luchini, Kristi L.
