Hi Florian,
Here is my two points:
1. If you read the mbboRecord.c thoroughly, you will realize that you don't have to set the values of fields *VL (ZRVL, ONVL ... FFVL are all default to zero) if you use prec->val instead of prec->rval in the mbbo device support write routine (write_mbbo( )) to put the data of prec->val to hardware/record link. But the RVAL will be always 0 in this case. I have developed an EPICS/Linux driver for one digitizer. The EPICS driver is based on the vendor's Linux APIs so that the driver doesn't access the digitizer's register directly. I always use the prec->val in the mbbo device support routines for this digitizer and I always ignore the configuration of *VL in the database. This works perfectly. Another way to test this is giving a try on a soft mbbo record (DTYP is "Soft Channel").
You may test this
epicsUInt32 *pvalues = &(prec->zrvl);
epicsUInt32 pvaluesSum = 0;
int i = 0;
for (i=0; i<15; i++) pvaluesSum += pvalues[i];
/* convert val to rval */
//if(prec->sdef) {
if(prec->sdef && (pvaluesSum>0)) {
On 2/15/13 5:27 AM, "Ralph Lange" <[email protected]> wrote:
>For 3.15:
>Should we change the record support to use the index (option number) if
>and only if all ..VL fields are zero?
>This would even match the regular soft support behavior that writes the
>index value.
>I can't imagine someone relying on device support always being called
>with zero, no matter which state the record is in.
>~Ralph
>On 02/15/2013 10:38 AM, Burkhard Kolb wrote:
>> Hi Florian,
>> yes, you have to set also the values. The numbering scheme
>>distinguishes between sixteen states,
>> but their value does not have to be 0, 1, 2, 4..., but could be
>>anything.
>> Burkhard
>> Dr. Burkhard Kolb
>> Tel +49 6159 712667
>> GSI Helmholtzzentrum für Schwerionenforschung GmbH
>> Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
>> Gesellschaft mit beschränkter Haftung
>> Sitz der Gesellschaft: Darmstadt
>> Handelsregister: Amtsgericht Darmstadt, HRB 1528
>> Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker, Peter
>>Hassenbach
>> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
>> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
>> Am 15.02.2013 um 10:14 schrieb Florian Feldbauer:
>>> Hey,
>>> I have written an AsynPortDriver for the TMCM142 1 axis stepper
>>>driver/controller
>>> The motor driver is connected via CAN bus and expects a message with 7
>>>bytes of data:
>>> byte 0: command number
>>> byte 1: parameter number (I'm using the addr parameter from the asyn
>>>interface)
>>> byte 2: motor number (only one motor can be connected to the driver so
>>>it is always 0)
>>> byte 3-6: data (32 bit signed int)
>>> For setting the microstep resolution of the motor driver the data has
>>>to be a number between
>>> 0 and 11, each coding a different resoultion.
>>> I wanted to use a mbbo record, which looks like this:
>>> record( mbbo, "PANDA:$(subsys):MOTOR:$(SECTOR):SAP:USTEPRESOLUTION" ) {
>>> field( DTYP, "asynUInt32" )
>>> field( OUT, "@asyn($(BUS),27,1)TMCM142_SAP" )
>>> field( ZRST, "2048 micro steps" )
>>> field( ONST, "1024 micro steps" )
>>> field( TWST, "512 micro steps" )
>>> field( THST, "256 micro steps" )
>>> field( FRST, "128 micro steps" )
>>> field( FVST, "64 micro steps" )
>>> field( SXST, "32 micro steps" )
>>> field( SVST, "16 micro steps" )
>>> field( EIST, "8 micro steps" )
>>> field( NIST, "4 micro steps" )
>>> field( TEST, "2 micro steps" )
>>> field( ELST, "1 micro steps" )
>>> Unfortunately, the value inside my writeInt32 function from the
>>>asynPortDriver is always 0.
>>> Do I have to set the ZRVL,...,ELVL fields for asynInt32? Or do I need
>>>another asyn interface for
>>> this record?
>>> Best regards,
>>> Florian
>>> | Dr. Florian Feldbauer |
>>> | Helmholtz-Institut Mainz / |
>>> | Johannes Gutenberg-Universität Mainz |
>>> | Johann-Joachim-Becher-Weg 45 |
>>> | D-55128 Mainz |
>>> | Office: 01/217 |
>>> | Phone: (+49)6131 / 39-25829 |
- RE: AsynInt32 device support and mbbo records Hu, Yong
- Re: AsynInt32 device support and mbbo records Ralph Lange
RE: aSub MAX_ARRAY_SIZE increase Hu, Yong
<2013>
2025
2026
<2013>
2025
2026
