1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: aSub MAX_ARRAY_SIZE increase
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 17 Feb 2013 15:24:58 +0000
Hi Euan,
I had the same problem as you a few months ago when I played with a digitizer with huge memory. What I did is just removing the macro MAX_ARRAY_SIZE and its associated codes from aSubRecord.c so that there won't be any limit on the array size. I have not seen any problem with this change since.
It is Big Data Epoch in EPICS community.
Cheers,
Yong
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Sunday, February 17, 2013 1:13 AM
To: [email protected]
Subject: aSub MAX_ARRAY_SIZE increase
Hi tech-talk,
I have an EPICS application that runs on Linux/Darwin where I need to increase the value of MAX_ARRAY_SIZE in aSubRecord.c from ten million to 200 million or possibly even 1000 million. Apart from creating a version of EPICS that is only locally compatible (and needing lots of memory to run) are there any likely problems with this change?
cheers,
Euan.
Euan Troup CSIRO Astronomy & Space Science    +61 2 9372 4660
[email protected]<mailto:[email protected]>
RE: aSub MAX_ARRAY_SIZE increase Dalesio, Leo
aSub MAX_ARRAY_SIZE increase Euan.Troup
Prev: aSub MAX_ARRAY_SIZE increase Euan.Troup
Next: Re: AsynInt32 device support and mbbo records Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: aSub MAX_ARRAY_SIZE increase Dalesio, Leo
