James,
Try taking that line out. MIBDIRS should be defined elsewhere. Or, make sure that it is.
Paul
On Feb 21, 2013, at 2:10 PM, James F Ross <[email protected]> wrote:
> I dont think it's an issue with the environment variable. I tried
> commenting them out and it gave the same syntax error about the
> dbLoadDatabase command.
> The IOC isn't getting far enough to get to the console output. Here
> is what I do after building it:
> 1. cd <TOP>/iocBoot/iocsnmp
> 2. ./st.cmd
> Output:
> ./st.cmd: line 7: syntax error near unexpected token `"MIBDIRS",'
> ./st.cmd: line 7: `epicsEnvSet("MIBDIRS", "+$(TOP)/mibs")'
> I'm running scientific linux 5.8 with epics base 3.14.12.1.
> Thanks
> James
> On Thu, Feb 21, 2013 at 2:56 PM, Eric Norum <[email protected]> wrote:
>> That's strange. Can you send all the IOC console output?
>> What IOC platform are you using?
>> I tried downloading, unpacking and building the SNMP tarball. When I run it I get:
>> #!../../bin/darwin-x86/wienerCrateExample
>> # Set up environment
>> # Need to add run-time expansion for crate support
>> epicsEnvSet("P","wienerCrate:")
>> epicsEnvSet("R","1:")
>> < envPaths
>> epicsEnvSet("ARCH","darwin-x86")
>> epicsEnvSet("IOC","iocwienerCrateExample")
>> epicsEnvSet("TOP","/Users/wenorum/src/SNMP/snmp/WienerCrate")
>> epicsEnvSet("SNMP","/Users/wenorum/src/SNMP/snmp")
>> epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base")
>> epicsEnvSet("MIBDIRS", "+/Users/wenorum/src/SNMP/snmp/WienerCrate/mibs")
>> epicsEnvSet("WCR_PREF", "admin WIENER-CRATE-MIB::")
>> # Register all support components
>> On Feb 21, 2013, at 11:42 AM, James F Ross <[email protected]> wrote:
>>> Paul,
>>> Ok, I'm starting from scratch with John's basic IOC and I'm going to
>>> write a very basic IOC just to turn the crate on and off and maybe
>>> read the voltages and currents.
>>> At the moment i'm trying to get the basic IOC to run, though, and am
>>> running into the following problem. I've emailed john but if you have
>>> any insight, that'd be nice as well:
>>> ./st.cmd
>>> The mib file is in that directory, so I'm not sure what it is
>>> complaining about. This is written into his st.cmd file, I didn't
>>> change anything.
>>> James
>> Eric Norum
>> [email protected]
- asyn and snmp James F Ross
- Re: asyn and snmp Paul Nord
- Re: asyn and snmp James F Ross
- Re: asyn and snmp Eric Norum
<2013>
2025
2026
<2013>
2025
2026
