1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn and snmp
To: James F Ross <[email protected]>
Date: Thu, 21 Feb 2013 12:41:04 -0800
I think that there's something wrong with the 'shebang' line at the top of your st.cmd.  It appears to be attempting to use the system shell instead of the IOC executable to interpret the st.cmd lines.
Try running the executable explicitly:
./../bin/darwin-x86/wienerCrateExample st.cmd
(where darwin-x86 would be replaced with whatever you have for EPICS_HOST_ARCH).
On Feb 21, 2013, at 12:10 PM, James F Ross <[email protected]> wrote:
> I dont think it's an issue with the environment variable.  I tried
> commenting them out and it gave the same syntax error about the
> dbLoadDatabase command.
> The IOC isn't getting far enough to get to the console output.  Here
> is what I do after building it:
> 1. cd <TOP>/iocBoot/iocsnmp
> 2. ./st.cmd
> Output:
> ./st.cmd: line 7: syntax error near unexpected token `"MIBDIRS",'
> ./st.cmd: line 7: `epicsEnvSet("MIBDIRS", "+$(TOP)/mibs")'
> I'm running scientific linux 5.8 with epics base 3.14.12.1.
> Thanks
> James
Re: asyn and snmp Jiro Fujita
asyn and snmp James F Ross
Re: asyn and snmp Paul Nord
Re: asyn and snmp James F Ross
Re: asyn and snmp Eric Norum
Prev: Re: asyn and snmp Paul Nord
Next: EPICS Modbus module + PLC Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: asyn and snmp Jiro Fujita
