On Tuesday, February 26, 2013 10:17:12 [email protected] wrote:
> Thank you for your reply. I have now disabled preemptive callback.
Ok.
> I am
> using ca_poll to process the CA client and FileDescriptorManager.process
> to run the portable channel access server. These are called together in a
> single loop. However, once the CA client has attached to a number of
> process variables, the CA background activity that runs due to the ca_poll
> seems to delay the call to FileDescriptorManager.process too much. This
> results in calls to caget for process variables in the portable channel
> access server timing out. Is there another way to do this?
Have you looked at
http://lansce.lanl.gov/epicsdata/ca/client/caX5Ftutor-1.html yet? It contains
a lot of CA client examples and explains what calls to use in which situation.
You might be interested in chapter 4 "Monitoring a PV" and there especially
the section named "An Example Program" under which you'll find (among else) a
desciption of fdmgr, how it works and how it is used.
> Also, is there
> a way to avoid having the CA client search for process variables on the
> portable channel access server, but still look for them on the localhost?
Set EPICS_CA_AUTO_ADDR_LIST to NO and EPICS_CA_ADDR_LIST so that the gateway
is excluded but localhost is included.
Cheers
Ben
PS: The above link to the CA tutorial is not linked to from the EPICS home
page (or at least not in any prominent place). Could this be changed? I found
these pages extremely useful when trying to get my head around the CA client
API.
> > On Monday, February 25, 2013 14:58:36 [email protected] wrote:
> >> I think it turns out that the problem was
> >> that I actually had preemptive callback enabled and I should not have.
> > Yes. If you use preemptive callback (i.e. multithreaded CA client) don't
> > create a FileDescriptorManager. It is only needed for single-threaded
> > clients
> > and can be used to centralize the call to select in case the CA client is
> > used
> > together with other stuff that wants to call select (such as a GUI
> > library).
> > Cheers
> > Ben Franksen
> > () ascii ribbon campaign - against html e-mail
> > /\ www.asciiribbon.org - against proprietary attachments
> > ________________________________
> > Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> > Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> > Forschungszentren e.V.
> > Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv.
> > Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> > Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> > Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> > Postadresse:
> > Hahn-Meitner-Platz 1
> > D-14109 Berlin
> > http://www.helmholtz-berlin.de
Ben Franksen
signature.asc
Description: This is a digitally signed message part.
- Re: caClient with PCAS Andrew Johnson
- Re: caClient with PCAS pthomas
- caClient with PCAS pthomas
- Re: caClient with PCAS Benjamin Franksen
Re: Alarms with CSS Pavel Maslov
RE: Question about epid record Mark Rivers
<2013>
2025
2026
<2013>
2025
2026
