1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strange Interaction between CA gateway and CAJ
To: [email protected]
Date: Thu, 28 Feb 2013 11:34:25 -0600
Hi Gary,
On 2013-02-28 Carr, Gary wrote:
> I have an application that needs to monitor changes in the NORD field of a
>  waveform record. Since we are running Channel Access 3.14.11, I cannot get
>  a monitor on the field, so I use a simple "get" to poll the field in Java.
>  Basically:
> Channel ic = context.createChannel("pvname.NORD");
> context.pendIO(timeout);
> int val = ((INT) ic.get(DBRType.INT,1)).getValue();
> Using jca context this works fine either reading thechannel directly, or
>  through a CA gateway. If I use a caj context in the same code, it works
>  fine reading the channel directly, but if I read through a CA gateway I
>  never see the NORD field change when the waveform processes.
That's because the gateway sets up a monitor on the channel and uses that
value when you do a ca_get from it.  It does that to try and reduce the load
on the IOCs if lots of scripts do ca_get operations on random channels.
There may be a flag you can give the gateway to prevent that behavior (but it
will increase the load on your IOCs), or you could patch the waveform record
in Base to make it post monitors on NORD — we've done that in the 3.15 branch,
and it's just a one-line change (line-numbers may vary):
=== modified file 'src/std/rec/waveformRecord.c'
--- src/std/rec/waveformRecord.c        2010-10-05 19:27:37 +0000
+++ src/std/rec/waveformRecord.c        2012-02-17 23:32:25 +0000
@@ -191,6 +191,7 @@
     if (prec->nord > prec->nelm)
         prec->nord = prec->nelm;
+    db_post_events(prec, &prec->nord, DBE_VALUE | DBE_LOG);
     return 0;
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: Strange Interaction between CA gateway and CAJ Eric Norum
Strange Interaction between CA gateway and CAJ Carr, Gary
Prev: Re: What I learned today... Andrew Johnson
Next: Re: Strange Interaction between CA gateway and CAJ Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Strange Interaction between CA gateway and CAJ Carr, Gary
