Hi Benjamin,
On 2013-02-28 Benjamin Franksen wrote:
> with the latest snapshot (http://www-
> csr.bessy.de/control/SoftDist/sequencer/releases/seq-snapshot-latest.tar.gz
> or darcs get
> http://www-csr.bessy.de/control/SoftDist/sequencer/repo/branch-2-1/ ) I
> can build the sequencer reliably under 3.15.0.1 (all patches applied),
> even with parallel make. however, I get a spurious message saying
> Can't find file 'vxTestHarnessRegistrars.dbd'
> that I do not understand and do not get with base 3.14.12.2. It looks as if
> the build is ok despite the message (make runtests runs through just fine),
> but if you have a hint how to get rid of the message I'd be glad.
I get several different issues. Using the latest 3.15 branch code and a
serial build the first error I saw was this:
/usr/bin/g++ -o decl -L/home/phoebus3/ANJ/epics/modules/soft/seq-
snapshot-2013-02-28/lib/linux-x86_64 -
L/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64 -Wl,-
rpath,/home/phoebus3/ANJ/epics/modules/soft/seq-snapshot-2013-02-28/lib/linux-
x86_64 -Wl,-rpath,/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64
-m64 decl.o -lseqSoftIoc -lseq -lpv -ldbRecStd -ldbCore -lca -lCom
decl.o: In function `main':
snapshot-2013-02-28/test/validate/O.linux-x86_64/../seqMain.c:118: undefined
reference to `seqSoftIoc_registerRecordDeviceDriver'
collect2: ld returned 1 exit status
make[3]: *** [decl] Error 1
make[3]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
snapshot-2013-02-28/test/validate/O.linux-x86_64'
I immediately went to the test/validate directory and ran make there.
tux% make
make: `vxTestHarness.db' is up to date.
Huh? In the O.linux-x86_64 directory I get the same seqMain error from above.
This is happening because in your test/validate/Makefile the rule for
vxTestHarness.db$(DEP) appears *above* the "include $(TOP)/configure/RULES"
line, contrary to the comment that follows. All rules *must* go below that
include or they interfere with the default rule. You should probably check
the other Makefiles for that too, I haven't looked.
With that issue out of the way, the seqMain error is happening because my 3.15
build has gcc's -fvisibility=hidden flag set. That makes it essential to
properly decorate all symbols that are going to be exported from a shared
library, thus matching the behavior of DLLs built on Windows. Unfortunately
the generated seqSoftIoc_registerRecordDeviceDriver() function is not (and
can't be) decorated, so it's not actually possible to link it from a library.
You have to link the .o file directly into each of your executables instead.
I removed the seqSoftIoc library from your Makefile and added the magic to set
xxx_SRCS = xxx.st $(seqSoftIoc_SRCS)
for all your test programs.
Ok, Finally I can see your error:
tux% make -sj4
tux%
Where is it coming from? Well if I run a serial make and look at the output
it occurs here:
perl -CSD /home/phoebus/ANJ/epics/base/mirror-3.15/bin/linux-
x86_64/makeIncludeDbd.pl base.dbd ../O.Common/vxTestHarnessRegistrars.dbd
vxTestHarnessInclude.dbd
make[1]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
make[1]: Entering directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
The fact that this came from the first build pass (when GNUmake says "Leaving"
followed by "Entering" the same directory) usually indicates that it's a
problem generating a dependency file, and in this case you don't have a rule
to generate the vxTestHarness.dbd$(DEP) file. If I add that as well the error
goes away:
tux% make clean
rm -rf O.linux-x86_64 O.vxWorks-ppc604_long O.vxWorks-ppc32
O.vxWorks-ppc32sf O.RTEMS-uC5282 O.Common
tux% make -sj4
tux%
I also ran the tests on linux-x86_64, which all passed BTW.
You don't need to set USR_DBDFLAGS for 3.15 so I commented it out, but I guess
it may be necessary for some earlier release of Base.
Patch file attached, but I only tried this with the latest 3.15 branch.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
--- Makefile.orig 2013-02-28 15:30:52.362346140 -0600
+++ Makefile 2013-02-28 18:02:16.091655151 -0600
@@ -62,20 +62,14 @@
#TESTPROD_HOST += ctest
# Libraries
-PROD_LIBS += seqSoftIoc
PROD_LIBS += seq pv
PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
-LIBRARY += seqSoftIoc
DBD += seqSoftIoc.dbd
seqSoftIoc_DBD += base.dbd
seqSoftIoc_SRCS += seqSoftIoc_registerRecordDeviceDriver.cpp
-seqSoftIoc_LIBS += seq pv
-seqSoftIoc_LIBS += $(EPICS_BASE_IOC_LIBS)
ifeq '$(EPICS_HAS_UNIT_TEST)' '1'
seqSoftIoc_SRCS += testSupport.c
@@ -91,15 +85,17 @@
vxTestHarness_DBD += base.dbd
vxTestHarness_DBD += $(COMMON_DIR)/vxTestHarnessRegistrars.dbd
-USR_DBDFLAGS += -I $(COMMON_DIR)
-TOUCH = $(PERL) -MExtUtils::Command -e touch
+# USR_DBDFLAGS += -I $(COMMON_DIR)
DB += vxTestHarness.db
-vxTestHarness.db$(DEP):
- $(TOUCH) $@
endif
+define template_SRCS
+$(1)_SRCS += $(1).st $(seqSoftIoc_SRCS)
+endef
+$(foreach st, $(TESTPROD_HOST), $(eval $(call template_SRCS,$(st))))
# PROD_RTEMS = rtemsTestHarness
# rtemsTestHarness_SRCS += $(TESTPROD_HOST::%=%.st)
@@ -109,6 +105,13 @@
# ADD RULES AFTER THIS LINE
+ifeq '$(EPICS_HAS_UNIT_TEST)' '1'
+vxTestHarness.db$(DEP):
+ @echo "$(COMMON_DIR)/vxTestHarness.db: ../Makefile" > $@
+vxTestHarness.dbd$(DEP):
+ @echo "$(COMMON_DIR)/vxTestHarness.dbd: ../Makefile" > $@
+endif
SOFTIOC=$(EPICS_BASE_BIN)/softIoc$(HOSTEXE)
SOFTDBD=$(EPICS_BASE)/dbd/softIoc.dbd
- Re: seq: benign(?) error message when building with R3.15 Benjamin Franksen
- seq: benign(?) error message when building with R3.15 Benjamin Franksen
RE: Crystal Logic goniometer Mark Rivers
答复: Crystal Logic goniometer 汪启胜
<2013>
2025
2026
<2013>
2025
2026
