1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seq: benign(?) error message when building with R3.15
To: <[email protected]>
Date: Fri, 1 Mar 2013 15:33:54 +0100
Thanks Andrew
I applied your patch (USR_DBDFLAGS addition is needed with 3.14.10, I added a
comment to explain that). I also made a number of changes to src/snc/Makefile
to restore builing with 3.14.8. The latest snapshot should now build with
3.14.8, 3.14.10, 3.14.12 and 3.15 (head); parallel build is supported from
3.14.12 onward, 'make runtests' from 3.14.10 onwards.
Ugh. That was a bit harder than I expected. (Note to self: remember to check
build compatibility with all support versions of base each time I make any
changes to any Makefile.)
If nothing comes up in the next few days I'll make a new release with these
changes.
Cheers
Ben
On Thursday, February 28, 2013 18:11:44 Andrew Johnson wrote:
> Hi Benjamin,
> On 2013-02-28 Benjamin Franksen wrote:
> > with the latest snapshot (http://www-
> > csr.bessy.de/control/SoftDist/sequencer/releases/seq-snapshot-latest.tar.g
> > z
> >  or darcs get
> >  http://www-csr.bessy.de/control/SoftDist/sequencer/repo/branch-2-1/ ) I
> >  can build the sequencer reliably under 3.15.0.1 (all patches applied),
> >  even with parallel make. however, I get a spurious message saying
> >   Can't find file 'vxTestHarnessRegistrars.dbd'
> > that I do not understand and do not get with base 3.14.12.2. It looks as
> > if
> > the build is ok despite the message (make runtests runs through just
> > fine),
> > but if you have a hint how to get rid of the message I'd be glad.
> I get several different issues.  Using the latest 3.15 branch code and a
> serial build the first error I saw was this:
> /usr/bin/g++ -o decl  -L/home/phoebus3/ANJ/epics/modules/soft/seq-
> snapshot-2013-02-28/lib/linux-x86_64 -
> L/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64 -Wl,-
> rpath,/home/phoebus3/ANJ/epics/modules/soft/seq-snapshot-2013-02-28/lib/linu
> x- x86_64
> -Wl,-rpath,/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64 -m64
> decl.o -lseqSoftIoc -lseq -lpv -ldbRecStd -ldbCore -lca -lCom decl.o: In
> function `main':
> snapshot-2013-02-28/test/validate/O.linux-x86_64/../seqMain.c:118: undefined
> reference to `seqSoftIoc_registerRecordDeviceDriver'
> collect2: ld returned 1 exit status
> make[3]: *** [decl] Error 1
> make[3]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
> snapshot-2013-02-28/test/validate/O.linux-x86_64'
> I immediately went to the test/validate directory and ran make there.
>     tux% make
>     make: `vxTestHarness.db' is up to date.
> Huh?  In the O.linux-x86_64 directory I get the same seqMain error from
> above.
> This is happening because in your test/validate/Makefile the rule for
> vxTestHarness.db$(DEP) appears *above* the "include $(TOP)/configure/RULES"
> line, contrary to the comment that follows.  All rules *must* go below that
> include or they interfere with the default rule.  You should probably check
> the other Makefiles for that too, I haven't looked.
> With that issue out of the way, the seqMain error is happening because my
> 3.15 build has gcc's -fvisibility=hidden flag set.  That makes it essential
> to properly decorate all symbols that are going to be exported from a
> shared library, thus matching the behavior of DLLs built on Windows.
> Unfortunately the generated seqSoftIoc_registerRecordDeviceDriver()
> function is not (and can't be) decorated, so it's not actually possible to
> link it from a library. You have to link the .o file directly into each of
> your executables instead.
> I removed the seqSoftIoc library from your Makefile and added the magic to
> set xxx_SRCS = xxx.st $(seqSoftIoc_SRCS)
> for all your test programs.
> Ok, Finally I can see your error:
>     tux% make -sj4
>     tux%
> Where is it coming from?  Well if I run a serial make and look at the output
> it occurs here:
> perl -CSD /home/phoebus/ANJ/epics/base/mirror-3.15/bin/linux-
> x86_64/makeIncludeDbd.pl base.dbd ../O.Common/vxTestHarnessRegistrars.dbd
> vxTestHarnessInclude.dbd
> make[1]: Leaving directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
> make[1]: Entering directory `/home/phoebus3/ANJ/epics/modules/soft/seq-
> The fact that this came from the first build pass (when GNUmake says
> "Leaving" followed by "Entering" the same directory) usually indicates that
> it's a problem generating a dependency file, and in this case you don't
> have a rule to generate the vxTestHarness.dbd$(DEP) file.  If I add that as
> well the error goes away:
>     tux% make clean
>     rm -rf O.linux-x86_64 O.vxWorks-ppc604_long O.vxWorks-ppc32
>      O.vxWorks-ppc32sf O.RTEMS-uC5282 O.Common
>     tux% make -sj4
>     tux%
> I also ran the tests on linux-x86_64, which all passed BTW.
> You don't need to set USR_DBDFLAGS for 3.15 so I commented it out, but I
> guess it may be necessary for some earlier release of Base.
> Patch file attached, but I only tried this with the latest 3.15 branch.
> - Andrew
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Attachment: signature.asc
Description: This is a digitally signed message part.
seq: benign(?) error message when building with R3.15 Benjamin Franksen
Re: seq: benign(?) error message when building with R3.15 Andrew Johnson
Prev: RE: JCA Error Lucas José
Next: Re: What I learned today... Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: seq: benign(?) error message when building with R3.15 Andrew Johnson
Next: Building an Epics module only for a target (not host) Florian Feldbauer
