1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing MEDM on UBUNTU 12.04
To: [email protected]
Cc: Kohler <[email protected]>
Date: Mon, 4 Mar 2013 11:01:11 -0600
Hi Ivan,
On 2013-03-04 Kohler wrote:
> If this helps I install the following packages to compile MEDM on Ubuntu
> 1204 and Ubuntu 1210.
Thanks for this:
> apt-get install autoconf libtool build-essential libmotif-dev
> apt-get install x11proto-print-dev libboost-program-options-dev
> apt-get install libxp-dev libreadline-gplv2-dev libxmu-dev
> apt-get install libxpm-dev        # for StripTool
> apt-get install re2c              # for sequencer in synApps
> apt-get install xfonts-100dpi     # for all the larger MEDM fonts
We don't use autoconf, libtool, or Boost in EPICS, what are those packages
needed for?  What does build-essential pull in?
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: Installing MEDM on UBUNTU 12.04 Kohler
Prev: RE: C++ logging framework for epics matthew.pearson
Next: getBounds Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing MEDM on UBUNTU 12.04 Kohler
Next: What I learned today... Benjamin Franksen
