1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM won't compile in Cygwin: "Too many open files"
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Mar 2013 19:02:11 +0000
Are you using parallel make, i.e. "make -j"?
From: [email protected] [[email protected]] on behalf of Poff, Mark A [[email protected]]
Sent: Wednesday, March 06, 2013 11:34 AM
To: [email protected]
Cc: Poff, Mark A
Subject: MEDM won't compile in Cygwin: "Too many open files"
Successfully compiled EPICS R3.15.0.1  in Cygwin (Windows 7 platform) , but when I try to subsequently compile MEDM 3.1.7 it fails with:
<…..>/base/extensions/configure/CONFIG:12:         ../configure/RELEASE: Too many open files
<…..>/base/extensions/configure/CONFIG:21:         <…..>/base/extensions/configure/CONFIG: Too many open files
<…..>/base/extensions/configure/CONFIG:25:         ../configure/CONFIG_SITE: Too many open files
<…..>/base/extensions/configure/RULES_DIRS:3:   <…..>/base/extensions/configure/RULES_DIRS: Too many open files
make: *** No targets specified and no makefile found.  Stop.
Not sure, but this seems to be a stack size problem which in a Linux environment could be solved with the “ulimit” command, but in Cygwin that command apparently doesn’t work – I get “cannot modify limit:  Invalid argument.”  Does anybody have a suggestion how I can get MEDM to compile in Cygwin?
The Boeing Company
MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Prev: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Next: RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM won't compile in Cygwin: "Too many open files" Andrew Johnson
