1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM won't compile in Cygwin: "Too many open files"
To: [email protected]
Cc: "Poff, Mark A" <[email protected]>
Date: Wed, 6 Mar 2013 13:27:05 -0600
Hi Mark,
On 2013-03-06 Poff, Mark A wrote:
> Successfully compiled EPICS R3.15.0.1  in Cygwin (Windows 7 platform) , but
Base 3.15.0.1 is not intended as a production release, although I'm not aware
of any changes to the CA client library code which would affect MEDM or the
other extensions.
Have you already tried building MEDM using the 3.14.12.x stable branch of
Base?  Did you extract the MEDM source into a proper 3.14 extensions build
tree?  There is a brief description of how to do this and a link to the
extensions/configure tar-file at
    http://www.aps.anl.gov/epics/extensions/configure/index.php
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Prev: RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Next: Automatic IOC configuration loading Bruno Seiva Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MEDM won't compile in Cygwin: "Too many open files" Mark Rivers
Next: RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
