1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM won't compile in Cygwin: "Too many open files"
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Cc: "Poff, Mark A" <[email protected]>
Date: Fri, 8 Mar 2013 13:53:06 +0000
Andrew,
Thanks for the information, and I did not fully appreciate that Base 3.15.0.1 was not intended as a production release.  I installed base 3.14.12.3, extracted MEDM into the recommended build tree, and this time did not have the "too many open files" issue.  (Note that I also realized that I had not previously set the X11 and MOTIF variables in CONFIG_SITE.cygwin-x86.cygwin-x86 correctly, so that may have been an issue as well.)
I eventually got a successful build, but now when I try to start MEDM it complains that it can't find some of the runtime (dll) libraries.  I'm going to work this issue for a while, if I get hopelessly stuck I'll submit another post.
Thanks again,
-----Original Message-----
Sent: Wednesday, March 06, 2013 2:27 PM
To: [email protected]
Cc: Poff, Mark A
Subject: Re: MEDM won't compile in Cygwin: "Too many open files"
Hi Mark,
On 2013-03-06 Poff, Mark A wrote:
> Successfully compiled EPICS R3.15.0.1  in Cygwin (Windows 7 platform)
> , but
Base 3.15.0.1 is not intended as a production release, although I'm not aware of any changes to the CA client library code which would affect MEDM or the other extensions.
Have you already tried building MEDM using the 3.14.12.x stable branch of Base?  Did you extract the MEDM source into a proper 3.14 extensions build tree?  There is a brief description of how to do this and a link to the extensions/configure tar-file at
    http://www.aps.anl.gov/epics/extensions/configure/index.php
- Andrew
There is no such thing as a free lunch.  When invited for lunch, it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
Re: MEDM won't compile in Cygwin: "Too many open files" Andrew Johnson
Prev: RE: Labview as Server and Probe as client, connection problem. kathryn.baker
Next: [no subject] Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM won't compile in Cygwin: "Too many open files" Andrew Johnson
Next: RE: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
