1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Example app won't run on cygwin
To: "'James F Ross'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 13 Mar 2013 14:51:30 +0000
What happens if you run it manually by typing from the iocboot/iocexample directory:
../../bin/cygwin-x86/example st.cmd
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
Sent: Wednesday, March 13, 2013 9:48 AM
To: EPICS Tech Talk
Subject: Example app won't run on cygwin
Hello all,
I've just managed to build epics base 3.14.11 on cygwin and I compiled
the example app, but when I try to run the st.cmd file there are some
odd errors that I've never encountered before.  Has anyone run into
these before?
Once the example app is built, here is a complete list of what I did:
$> cd /home/jfross/epics/exampleApp/iocBoot/iocexample
$> chmod +x st.cmd
$> ./st.cmd
C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>#!../../bin/cygwin-x86/example
'#!..' is not recognized as an internal or external command,
operable program or batch file.
C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>## You may
have to change example to something else
'##' is not recognized as an internal or external command,
everywhere it appears in this file
The syntax of the command is incorrect.
C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>< envPaths
Re: Example app won't run on cygwin James F Ross
Prev: Example app won't run on cygwin James F Ross
Next: Re: Example app won't run on cygwin James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
