That works, though I do get a number of errors when the IOC is running:
../online_notify.c: CA beacon routing (connect to
"169.254.255.255:5065") error was "Network is unreachable"
That may just be due to the internet connection here rather than any
problems with st.cm.
James
On Wed, Mar 13, 2013 at 10:51 AM, Mark Rivers <[email protected]> wrote:
> What happens if you run it manually by typing from the iocboot/iocexample directory:
> ../../bin/cygwin-x86/example st.cmd
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
> Sent: Wednesday, March 13, 2013 9:48 AM
> To: EPICS Tech Talk
> Subject: Example app won't run on cygwin
> Hello all,
> I've just managed to build epics base 3.14.11 on cygwin and I compiled
> the example app, but when I try to run the st.cmd file there are some
> odd errors that I've never encountered before. Has anyone run into
> these before?
> Once the example app is built, here is a complete list of what I did:
> $> cd /home/jfross/epics/exampleApp/iocBoot/iocexample
> $> chmod +x st.cmd
> $> ./st.cmd
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>#!../../bin/cygwin-x86/example
> '#!..' is not recognized as an internal or external command,
> operable program or batch file.
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>## You may
> have to change example to something else
> '##' is not recognized as an internal or external command,
> everywhere it appears in this file
> The syntax of the command is incorrect.
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>< envPaths
- RE: Example app won't run on cygwin Mark Rivers
- Example app won't run on cygwin James F Ross
<2013>
2025
2026
<2013>
2025
2026
