1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: User of AsynInt32Array
To: "'Vikram Bhagat'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Mar 2013 15:19:13 +0000
If you search the asyn module for .db files containing the string “Array” you will find the following examples:
corvette:~/devel/asyn>find . -name '*.db' -exec grep -H Array {} \;
./db/testAsynPortDriver.db:    field(DTYP, "asynFloat64ArrayIn")
./db/testErrors.db:#  Records that use devAsynXXXArray                               #
./db/testErrors.db:    field(DTYP, "asynInt8ArrayIn")
./db/testErrors.db:    field(DTYP, "asynInt16ArrayIn")
./db/testErrors.db:    field(DTYP, "asynInt32ArrayIn")
./db/testErrors.db:    field(DTYP, "asynFloat32ArrayIn")
./db/testErrors.db:    field(DTYP, "asynFloat64ArrayIn")
./testErrorsApp/Db/testErrors.db:#  Records that use devAsynXXXArray                               #
./testErrorsApp/Db/testErrors.db:    field(DTYP, "asynInt8ArrayIn")
./testErrorsApp/Db/testErrors.db:    field(DTYP, "asynInt16ArrayIn")
./testErrorsApp/Db/testErrors.db:    field(DTYP, "asynInt32ArrayIn")
./testErrorsApp/Db/testErrors.db:    field(DTYP, "asynFloat32ArrayIn")
./testErrorsApp/Db/testErrors.db:    field(DTYP, "asynFloat64ArrayIn")
./testAsynPortDriverApp/Db/testAsynPortDriver.db:    field(DTYP, "asynFloat64ArrayIn")
So testErrorsApp/Db has examples of all of the asynXXXArray device support, and testAsynPortDriver has an example of asynFloat64Array, which is just like asynInt32Array but with a different data type.
asyn/devEpics/devAsynInt32Array.dbd contains the strings that you must put in the DTYP field of your waveform records:
corvette:asyn/asyn/devEpics>more devAsynInt32Array.dbd
device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
From: [email protected] [mailto:[email protected]] On Behalf Of Vikram Bhagat
Sent: Wednesday, March 20, 2013 10:05 AM
To: [email protected]
Subject: User of AsynInt32Array
Hello all,
       I want to know about how to use asynInt32Array,
Actually on AsynDriver.pdf i could find few information about it.
typedef struct asynXXXArray {
asynStatus (*write)(void *drvPvt, asynUser *pasynUser, epicsXXX *value, size_t nelements);
asynStatus (*read)(void *drvPvt, asynUser *pasynUser, epicsXXX *value, size_t nelements, size_t *nIn);
asynStatus (*registerInterruptUser)(void *drvPvt, asynUser *pasynUser, interruptCallbackXXXArray callback,void *userPvt,void **registrarPvt);
asynStatus (*cancelInterruptUser)(void *drvPvt, asynUser *pasynUser, void *registrarPvt);
} asynXXXArray;
but not detail information how  write and read methods can be used and what should me my db file content for read and write operation.
Like provided for asynInt32
record(ai,"aiInt32") {
                        field(SCAN,"I/O Intr")
                        field(DTYP,"asynInt32")
                        field(INP,"@asyn($(port),$(addr))")
                        field(EGUF,"10.0")
                        field(EGUL,"-10.0")
                        field(PREC,"3")
where can i find the detail user manual / application developer guide?
Thanks
User of AsynInt32Array Vikram Bhagat
Prev: User of AsynInt32Array Vikram Bhagat
Next: RE: User of AsynInt32Array ian.gillingham
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
