1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAsynIPPort question
To: "'Sinisa Veseli'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Mar 2013 19:12:20 +0000
The openSocket method should be deprecated, it is really not needed and should be removed in a future release.  I actually thought we had already done that.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Sinisa Veseli
Sent: Wednesday, March 20, 2013 1:54 PM
To: [email protected]
Subject: Re: drvAsynIPPort question
I would also agree that existing interfaces could be enhanced to
simplify/clarify usage, without modifying what is already there. For
example, in asynOctetSyncIO.h I see the following methods:
/*asynOctetSyncIO methods*/
static asynStatus connect(const char *port, int addr,
                                asynUser **ppasynUser, const char *drvInfo);
static asynStatus disconnect(asynUser *pasynUser);
static asynStatus openSocket(const char *server, int port,
                                          char **portName);
In particular, there is no "closeSocket()" method that I would expect to
see (and that would match the "openSocket()" method). Similar statement
can be made for various "configureIPXXX" methods.
Another possibility would be to introduce completely new package derived
from existing asyn, that would not have to be backwards compatible.
Sinisa
On 03/20/2013 01:39 PM, J. Lewis Muir wrote:
> On 3/20/13 12:43 PM, Mark Rivers wrote:
>> Unfortunately we need to live with these names, it's too late to change them now.
> Hi, Mark.
> Thanks for your explanation.  That is really confusing.
> I agree that it's too late to change the names, but have you considered
> adding new names?  That way, things could be more clear for new
> development that doesn't need to be backward compatible.  It could also
> make the documentation clearer since, for old names that are poor, you
> could refer to the new names they map to.
> To make new names, you could append the digit '2' to the names:
> connect2, disconnect2, connectDevice2, etc.  Or you could add the words
> 'to' or 'from' to the names: connectTo, disconnectFrom, connectToDevice,
> etc.  Or you could change the vocabulary to words like "bind", "attach",
> etc.  Or there are probably other good schemes.
> Lewis
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
drvAsynIPPort question Sinisa Veseli
RE: drvAsynIPPort question Mark Rivers
Re: drvAsynIPPort question J. Lewis Muir
Re: drvAsynIPPort question Sinisa Veseli
Prev: Re: drvAsynIPPort question Sinisa Veseli
Next: using debian package for camac? Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: delay before alarm on alarm handler James F Ross
