1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: anyone using MOXA's embedded computer UC8410 as softioc?
To: tech-talk <[email protected]>
Date: Wed, 27 Mar 2013 20:24:20 +0800
hi, all:
After I cross-compiled an EPICS example application and downloaded to UC8410, it shows the following errors:
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Jan 23 2013
terminate called after throwing an instance of '__gnu_cxx::__concurrence_broadcast_error'
  what():  __gnu_cxx::__concurrence_broadcast_error
Aborted
It seems the reason is come from new version gcc. Has anybody solved this? thanks a lot in advance.
Best wishes
Geyang 2013-03-27
Re: anyone using MOXA's embedded computer UC8410 as softioc? Andrew Johnson
Prev: Fix length of exponent in Streamdevice %E Florian Feldbauer
Next: Stanford Research SR630 Thermocouple monitor Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: Re: Fix length of exponent in Streamdevice %E Florian Feldbauer
Next: Re: anyone using MOXA's embedded computer UC8410 as softioc? Andrew Johnson
