1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: anyone using MOXA's embedded computer UC8410 as softioc?
To: [email protected], "marco_hair@163" <[email protected]>
Date: Wed, 27 Mar 2013 09:49:19 -0500
On 2013-03-27 Silver wrote:
> After I cross-compiled an EPICS example application and downloaded to
>  UC8410, it shows the following errors:
> Starting iocInit
> # ## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
> ## EPICS Base built Jan 23 2013
> # terminate called after throwing an instance of
>  '__gnu_cxx::__concurrence_broadcast_error' what():
> Aborted
Based on the results from Googling for __concurrence_broadcast_error it seems
like this may be a problem if you link an application statically with pthread
(which EPICS requires).  This may be related to a specific version of gcc, so
if you have any other version available try using that instead, or change your
build to use dynamic linking (STATIC_BUILD=NO, SHARED_LIBRARIES=YES).
Those are only suggestions, I don't know what is actually causing this or what
the exception means.
- Andrew
There has grown up in the minds of certain groups in this country the
notion that because a man or corporation has made a profit out of the
public for a number of years, the government and the courts are charged
with the duty of guaranteeing such profit in the future, even in the face
of changing circumstances and contrary to public interest. This strange
doctrine is not supported by statute or common law. Neither individuals
nor corporations have any right to come into court and ask that the clock
of history be stopped, or turned back. -- Robert A Heinlein, Life-Line
Re: Re: anyone using MOXA's embedded computer UC8410 as softioc? Silver
Prev: RE: Fix length of exponent in Streamdevice %E peter.owens
Next: Re: Re: anyone using MOXA's embedded computer UC8410 as softioc? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: anyone using MOXA's embedded computer UC8410 as softioc? Silver
