Hi Jiro,
On 2013-04-05 you wrote:
> I too am interested in EPICS performance test/benchmark. I have downloaded
> the soft-test regression test suite, but could you please explain how to
> use it and how to interpret the result?
You build it like any other EPICS support module by editing the
configure/RELEASE file to set EPICS_BASE and then running make. Once it has
built you can manually run any of the tests, which can be found in the various
*App directories. Each of them has a README file and maybe some other files
containing notes or old results. The performApp/README file contains these
instructions:
> This is a record processing performance test
> 1. Boot the IOC
> on vxWorks boot with CMDLINE set to st.cmd
> on RTEMS boot with CMDLINE set to perform.main
> on others run ../../bin/<arch>/perform perform.main
> 2. Run the timing test
> on vxWorks execute
> sp timeproc,"mrkfanout",1000
> on others execute
> See the file TIMING for comparison data.
It should tell you to cd into the iocBoot/iocperform directory first, which is
where the startup scripts referred to above are found, but that instruction
seems to have been omitted. The test measures how quickly the IOC can process
a chain of 103 calc and ai records which are all forward-linked together using
database links. It measures that 1000 times, and reports the total and
average time for the processing chain (it says recordsPerSecond, but that's
actually wrong, it is timing the whole chain).
The performApp/TIMING file contains some past results on various kinds of CPU
and OS. It's interesting to note that an MVME167 board could run the chain at
189 Hz under EPICS 3.12.2, but it was down to 140 Hz by EPICS 3.14.9.
The dbcaPerformApp is less interesting, it measures how long the IOC takes to
modify record link fields at run-time. I'd have to read the code directly to
understand the details though.
Jeff Hill builds a CA timing test program within Base. See
http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#catime
for a few details.
HTH,
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Re: EPICS performance test/benchmark Jiro Fujita
RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Mark Rivers
<2013>
2025
2026
asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
<2013>
2025
2026
