1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Device and Asyn
To: Eric Norum <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Mon, 08 Apr 2013 17:40:32 +0100
Thank you for the suggestion, I will give it a try.
Kind regards, Alan
On 04/08/2013 04:59 PM, Eric Norum wrote:
Perhaps this could be related to the patch: StreamDevice-2-6-patch20121113
Try applying that to the 2-6 code and see if it fixes things.
On Apr 8, 2013, at 8:51 AM, Alan Greer <[email protected]> wrote:
Hi, I have been carrying out some additional tests.
I checked the flush operation in my driver and it does print "flush".
I then started looking at versions.  I have discovered that it works as expected if I use stream device version 2-5 instead of 2-6.  In this situation I see a flush followed by a write.
Kind regards, Alan
On 04/08/2013 04:35 PM, Mark Rivers wrote:
I can't think of any reason why it would be doing a read.  asyn device support does attempt a read at iocInit on many output records, but not on stringout records.
Could this be from a "flush" operation?  Your driver is printing the message "device read"?
Eric Norum
[email protected]
Re: Stream Device and Asyn Dirk Zimoch
Stream Device and Asyn Alan Greer
RE: Stream Device and Asyn Mark Rivers
Re: Stream Device and Asyn Alan Greer
Re: Stream Device and Asyn Eric Norum
Prev: Re: Stream Device and Asyn Eric Norum
Next: RE: Newport Piezo USB Controllers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Stream Device and Asyn Dirk Zimoch
