1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS opi refresh
To: <[email protected]>
Cc: Márcio Paduan Donadio <[email protected]>
Date: Mon, 15 Apr 2013 11:29:35 -0300
        Hello all.
    I have an OPI that sends some data to Stream Device records that are connected to an equipment using serial RS232. This operation is started with a button press. I don't want this button to be pressed again while the data is being transfered to my equipment. So, I tried to disable the button in the beginnig of the script, and reenable it at the end. But what I see is an enabled button until the end of the data transfer. Only at the end of the script I can see a quick transition of the button to disabled state and again to enabled.
    Between each data I need to transfer, I use time.sleep, because my equipment need some time to process the data before receiveing the next one.
    My python script is the following:
button = widgetController.getWidgetModel()
button.setPropertyValue("enabled", False)
button.setPropertyValue("text", "Programming\nPlease, Wait")
(data transfer code, with some time.sleep functions...)
button.setPropertyValue("text", "Program Furnace")
button.setPropertyValue("enabled", True)
    Is there a way to force the OPI refresh, as the disabled status of the button is shown?
Engenheiro de Computação - Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron ? (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
+ 55 (19) 3512-3520 - [email protected]
www.lnls.cnpem.br
Re: CSS opi refresh Kasemir, Kay
Prev: Re: Problem in installing asyn4-19 in mint13 system Eric Norum
Next: Re: CSS opi refresh Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
