1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux USB serial questions
To: [email protected]
Date: Thu, 18 Apr 2013 14:40:08 -0500
Hi Mark,
On 2013-04-18 Mark Rivers wrote:
> I then tried to run modprobe for the new device:
> >sudo modprobe ftdi_sio vendor=0x104d product=0x3000
The modprobe command merely tells the Kernel 'please make sure this module
(driver in your case) is loaded'.  Once it has been loaded issuing the
modprobe command again won't have any effect (unless it gets unloaded first,
which won't necessarily happen immediately that you unplug the first USB at
which point the driver is no longer needed, although eventually with no
devices connected the kernel might realize this and throw it out
automatically).
> There is still only device ttyUSB0, not a new ttyUSB1.
> What am I doing wrong?
I don't know for sure, but there has to be a way to tell the driver that a new
device has been plugged in.  I would normally expect the udev mechanism to do
that, so you might find the answer by reading the document that Eric pointed
to.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Linux USB serial questions Mark Rivers
RE: Linux USB serial questions Mark Rivers
Prev: Re: Linux USB serial questions Dale L. Brewe
Next: RE: Linux USB serial questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Linux USB serial questions Jeong Han Lee
