1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linux USB serial questions
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 18 Apr 2013 20:15:03 +0000
> With no /dev/ttyUSB* device files, what happens if the second device is
> plugged in first?
Without unplugging the devices I can unload the driver
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -r -v ftdi_sio
rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko
rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
At this point there are no /dev/ttyUSB devices:
Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB*
ls: No match.
Now I load the driver for model 3006
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3006 debug
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3006 debug
It works, and ttyUSB0 exists:
Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Apr 18 15:09 /dev/ttyUSB0
Now I unload the driver again:
No /dev/ttyUSB devices:
ls: No match.
Now I load the driver but for model 3000 this time:
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3000 debug
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3000 debug
So it works.  But I don't know how to also have it recognize the second device.  As Andrew said, loading the driver again does nothing:
I'll look into udev.
Sent: Thursday, April 18, 2013 2:17 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Linux USB serial questions
On 4/18/13 1:21 PM, Mark Rivers wrote:
> Thanks for all the replies I've received so far.  I am still reading and understanding them.
> But now I have a more fundamental question, there is something I am not understanding about modprobe I think.
> I now have 2 different USB ftdi_sio devices.  Both are manufactured by Newport but they are different models.
> This is what lsusb shows for these devices:
> Colorado:motor/iocBoot/iocWithAsyn>/usr/sbin/lsusb
> Bus 004 Device 007: ID 104d:3006 Newport Corporation
> Bus 002 Device 004: ID 104d:3000 Newport Corporation
> Initially I plugged in the device with model=3006.  I then did modprobe to load the ftdi_sio driver for that vendor and model, and it created /dev/ttyUSB0.  It works fine, I can control it with no problems.
> Now I plugged in the second device with model=3000, leaving the first device also plugged in.  The new device shows up with lsusb, as seen above.  However, it did not create a /dev/ttyUSBn for that device.
> I then tried to run modprobe for the new device:
>> sudo modprobe ftdi_sio vendor=0x104d product=0x3000
> There is no error message.  However, it did not create a new /dev/ttyUSBn device:
>> ls -l /dev/ttyUSB*
> crw-rw-rw- 1 root dialout 188, 0 Apr 18 13:10 /dev/ttyUSB0
> There is still only device ttyUSB0, not a new ttyUSB1.
> What am I doing wrong?
Hi, Mark.
plugged in first?  Does it get assigned /dev/ttyUSB0?
Another thing to try would be to add the "debug" keyword to the end of
the modprobe command, and see if you get anything helpful in dmesg (or a
log file).
Lewis
Re: Linux USB serial questions Jennings Guy
Re: Linux USB serial questions J. Lewis Muir
Linux USB serial questions Mark Rivers
RE: Linux USB serial questions Mark Rivers
Prev: Re: Linux USB serial questions Andrew Johnson
Next: Re: Linux USB serial questions Jennings Guy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linux USB serial questions J. Lewis Muir
