1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux USB serial questions
Date: Thu, 18 Apr 2013 14:17:30 -0500
On 4/18/13 1:21 PM, Mark Rivers wrote:
> Thanks for all the replies I've received so far.  I am still reading and understanding them.
> But now I have a more fundamental question, there is something I am not understanding about modprobe I think.
> I now have 2 different USB ftdi_sio devices.  Both are manufactured by Newport but they are different models.
> This is what lsusb shows for these devices:
> Colorado:motor/iocBoot/iocWithAsyn>/usr/sbin/lsusb
> Bus 004 Device 007: ID 104d:3006 Newport Corporation
> Bus 002 Device 004: ID 104d:3000 Newport Corporation
> Initially I plugged in the device with model=3006.  I then did modprobe to load the ftdi_sio driver for that vendor and model, and it created /dev/ttyUSB0.  It works fine, I can control it with no problems.
> Now I plugged in the second device with model=3000, leaving the first device also plugged in.  The new device shows up with lsusb, as seen above.  However, it did not create a /dev/ttyUSBn for that device.
> I then tried to run modprobe for the new device:
>> sudo modprobe ftdi_sio vendor=0x104d product=0x3000
> There is no error message.  However, it did not create a new /dev/ttyUSBn device:
>> ls -l /dev/ttyUSB*
> crw-rw-rw- 1 root dialout 188, 0 Apr 18 13:10 /dev/ttyUSB0
> There is still only device ttyUSB0, not a new ttyUSB1.
> What am I doing wrong?
Hi, Mark.
With no /dev/ttyUSB* device files, what happens if the second device is
plugged in first?  Does it get assigned /dev/ttyUSB0?
Another thing to try would be to add the "debug" keyword to the end of
the modprobe command, and see if you get anything helpful in dmesg (or a
log file).
Lewis
RE: Linux USB serial questions Mark Rivers
Prev: RE: Linux USB serial questions Mark Rivers
Next: RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Linux USB serial questions Mark Rivers
