On 4/18/13 3:15 PM, Mark Rivers wrote:
>> With no /dev/ttyUSB* device files, what happens if the second device is
>> plugged in first?
> Without unplugging the devices I can unload the driver
> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -r -v ftdi_sio
> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko
> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
> At this point there are no /dev/ttyUSB devices:
> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB*
> ls: No match.
> Now I load the driver for model 3006
> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3006 debug
> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3006 debug
> It works, and ttyUSB0 exists:
> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB0
> crw-rw---- 1 root dialout 188, 0 Apr 18 15:09 /dev/ttyUSB0
> Now I unload the driver again:
> No /dev/ttyUSB devices:
> ls: No match.
> Now I load the driver but for model 3000 this time:
> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3000 debug
> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3000 debug
> So it works. But I don't know how to also have it recognize the second device. As Andrew said, loading the driver again does nothing:
> I'll look into udev.
Hi, Mark.
I still think your modprobe command should work.
Do you still have your 81-Agilis.rules udev rules file loaded containing:
SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3000", MODE="0666"
What happens if you add another rule for model 3006?
SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3006", MODE="0666"
What happens if you connect both devices, but after connecting the
second, wait 60 seconds in case the /dev/ttyUSB1 file is somehow slow to
show up?
Lewis
- Re: Linux USB serial questions Jennings Guy
- Linux USB serial questions Mark Rivers
- RE: Linux USB serial questions Mark Rivers
- Re: Linux USB serial questions J. Lewis Muir
<2013>
2025
2026
<2013>
2025
2026
