1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux USB serial questions
To: "J. Lewis Muir" <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Thu, 18 Apr 2013 16:06:21 -0500
I don't think it can work in that kernel - the ftdi_sio module only allows
a single vendor:product pair to be passed as a parameter and udev will
only see events for devices that are recognised by the ftdi_sio module.
Guy Jennings
On Apr 18, 2013, at 4:00 PM, "J. Lewis Muir" <[email protected]> wrote:
> On 4/18/13 3:15 PM, Mark Rivers wrote:
>>> With no /dev/ttyUSB* device files, what happens if the second device is
>>> plugged in first?
>> Without unplugging the devices I can unload the driver
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -r -v ftdi_sio
>> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko
>> rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
>> At this point there are no /dev/ttyUSB devices:
>> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB*
>> ls: No match.
>> Now I load the driver for model 3006
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3006 debug
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3006 debug
>> It works, and ttyUSB0 exists:
>> Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB0
>> crw-rw---- 1 root dialout 188, 0 Apr 18 15:09 /dev/ttyUSB0
>> Now I unload the driver again:
>> No /dev/ttyUSB devices:
>> ls: No match.
>> Now I load the driver but for model 3000 this time:
>> Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3000 debug
>> insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3000 debug
>> So it works.  But I don't know how to also have it recognize the second device.  As Andrew said, loading the driver again does nothing:
>> I'll look into udev.
> Hi, Mark.
> I still think your modprobe command should work.
> Do you still have your 81-Agilis.rules udev rules file loaded containing:
>  SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3000", MODE="0666"
> What happens if you add another rule for model 3006?
>  SYSFS{idVendor}=="104d", ATTRS{idProduct}=="3006", MODE="0666"
> What happens if you connect both devices, but after connecting the
> second, wait 60 seconds in case the /dev/ttyUSB1 file is somehow slow to
> show up?
> Lewis
Re: Linux USB serial questions J. Lewis Muir
Linux USB serial questions Mark Rivers
RE: Linux USB serial questions Mark Rivers
Prev: Re: Linux USB serial questions J. Lewis Muir
Next: Re: Linux USB serial questions J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
