1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux USB serial questions
To: [email protected]
Cc: Andrew Gomella <[email protected]>
Date: Thu, 18 Apr 2013 17:12:45 -0500
Hi Mark,
On 2013-04-18 Mark Rivers wrote:
> I don't have a serious need for this device, but there is an EPICS user at
> NIH, Andrew Gomella who needs to control 18 of the model 3006 devices,
> which he is planning to do from a single Linux box.
> Is this possible, even in kernel 3.8?
It should be possible even with your kernel version.  The issue that Guy
described is that the driver can only talk to one *type* of device at once; so
as long as all 18 are the same model 3006 with the same product ID he should
be fine.
The other question is whether it provides a serial number attribute that can
be used in a udev configuration file to ensure that the /dev/ttyUSB* nodes
always map to the same physical devices. If there is no such attribute then
unplugging 2 devices and plugging them back in could cause the mapping to
change, which could be disastrous.  Of course managing all 18 units and
replacing them with spares still becomes a rather complicated chore.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Re: Linux USB serial questions Guy Jennings
Linux USB serial questions Mark Rivers
Re: Linux USB serial questions J. Lewis Muir
RE: Linux USB serial questions Mark Rivers
Prev: RE: Linux USB serial questions Mark Rivers
Next: Re: Linux USB serial questions J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Linux USB serial questions Jim Chen
Next: Re: Linux USB serial questions Guy Jennings
