1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Add choice to dbd file
To: Andrew Johnson <[email protected]>, Bruno Santos <[email protected]>
Date: Mon, 22 Apr 2013 17:03:14 -0700
Just out of curiosity, how does epics knows that
"60 seconds" is actually 60 * 1 second
In other words, what if I write in my dbd file
choice(menuScan60_second,"1 minute")
or
choice(menuScan1_minute,"1 minute")
Why are those entries different from
choice(menuScan60_second,"60 second")
Emmanuel
> From: [email protected]
> To: [email protected]
> Subject: Re: Add choice to dbd file
> Date: Fri, 19 Apr 2013 10:53:51 -0500
> CC: [email protected]
> Hi Bruno,
> On 2013-04-19 Bruno Santos wrote:
> > Anybody know how I can put this line "choice(menuScan60_second,"60
> > second")" permanently on the dbd file generated after compilation? Note
> > that I can put this manually but if I recompile the line is not kept...
> Copy the menuScan.dbd file from Base into your own IOC application area,
> modify it as you need and add it to your IOC's Makefile like this
> DBD += menuScan.dbd
> The local copy will override the version of the file in Base.
> - Andrew
> It is difficult to get a man to understand something, when his salary
> depends upon his not understanding it. -- Upton Sinclair
Re: Add choice to dbd file Eric Norum
Re: Add choice to dbd file Andrew Johnson
Add choice to dbd file Bruno Santos
Prev: Re: Crash when using access security zhaozhuo
Next: Re: Add choice to dbd file Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Add choice to dbd file Bruno Santos
