1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Redundancy
To: Steven Goff <[email protected]>
Cc: [email protected]
Date: Tue, 30 Apr 2013 09:13:20 -0600
On 2/14/2013 8:26 AM, Steven Goff wrote:
I have come across some charts about redundant IOCs. I believe it was originally done on vxworks.
Is that available on the Linux platform?
And where can I get more info on the redundancy concerning epics.
Jörg is maintaining it. However I recently sent him code with several modifications to additional features.
Here are my improvements:
1) Added support for DBADDR fields and larger fields (like waveform val fields) 2) Added the ability to specify that some records should not be synced (via info nodes) 3) Added the ability to only pause channel access (and continue commanding hardware) 4) setup the CCE to post an event on the slave when it becomes in sync (to trigger record processing if desired).
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Redundancy Steven Goff
Prev: Re: EPICS Extensions Compilation Errors murad ali
Next: Re: EPICS Extensions Compilation Errors Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Redundancy Clausen, Matthias
Next: ezcaIDL updates Mark Rivers
