I see that your error messages refer to a config directory so I think you downloaded "Extensions build config files (R3.13)" which are very old files for EPICS R3.13 builds. You should download the "Extensions build configure files (R3.14)". from the extensions web page.
After you download and unzip the file to create your extensions tree you should set EPICS_BASE in the extensions/configure/RELEASE file to your EPICS base top directory.
----- Original Message -----
To: [email protected]
Sent: Tuesday, April 30, 2013 2:26:22 AM
Subject: Re: EPICS Extensions Compilation Errors
After Making Some changes here and there in RElease files
Now I am Stuck Here for compiling MEDM:
root@murad-desktop:/opt/epics/extensions/src/medm# make
../../config/CONFIG_EXTENSIONS:68: /opt/epics/config/CONFIG: No such file or directory
Makefile:16: /opt/epics/config/RULES_DIRS: No such file or directory
make: *** No rule to make target `/opt/epics/config/RULES_DIRS'. Stop.
On Mon, Apr 29, 2013 at 8:52 AM, murad ali < [email protected] > wrote:
I have Ubuntu 11.4 Installed. I want to Install EPICS Base and MEDM following Instructions on (Download the distributions tarballs from EPICS.doc attached) . please refer to Configure the Extensions Section in this File.
EPICS Base is Installed and Compiled (Base Installation Attached)
While Compiling MEDM the erorr occures during make (extensions error attached)
kindly let me tell that how can I compile MEDM properly.
Also what are other alternatives to MEDM. CSS is just like MEDM or some other thing.
An Early Response is required
Regards
Murad Ali
- Re: EPICS Extensions Compilation Errors murad ali
Re: Redundancy Scott Baily
Would like to add regular expressions to dbpr Zelazny, Michael Stanley
<2013>
2025
2026
Re: EPICS Extensions Compilation Errors Pete Jemian
<2013>
2025
2026
