Well, actually, the program compiled but the sequencer program doesn't seem to be loading. Below is everything the IOC says when running st.cmd. There should be some messages I built into the .stt file to say when a state is entered (including one right as the first state occurs), but all I get is: I've included the full read out when the IOC starts below. If anyone has any ideas as to what may be the problem, I'd appreciate the help. The cas warnings are fairly common and I've seen them in other IOCs without causing problems.numMonitoredChans 0 firstMonitorCount 0 assignCount 7 firstConnectCount 6 numMonitoredChans 0 firstMonitorCount 0 assignCount 7 firstConnectCount 6 enumMonitoredChans 0 firstMonitorCount 0 assignCount 7 firstConnectCount 6 #!../../bin/linux-x86/pxlCooling ## You may have to change pxlCooling to something else ## everywhere it appears in this file < envPaths epicsEnvSet(ARCH,"linux-x86") epicsEnvSet(IOC,"iocPXLCooling") epicsEnvSet(TOP,"/home/sysuser/epics.3.14.12.1/hft_sc/pixel/PXL-Cooling") epicsEnvSet(SNCSEQ,"/home/sysuser/epics/synApps_5_5/support/seq-2-0-12") epicsEnvSet(EPICS_BASE,"/home/sysuser/epics.3.14.12.1/base-3.14.12.1") cd /home/sysuser/epics.3.14.12.1/hft_sc/pixel/PXL-Cooling ## Register all support components dbLoadDatabase("dbd/pxlCooling.dbd",0,0) pxlCooling_registerRecordDeviceDriver(pdbbase) ## Load record instances dbLoadRecords("db/pxlCooling.db") cd /home/sysuser/epics.3.14.12.1/hft_sc/pixel/PXL-Cooling/iocBoot/iocPXLCooling iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.12.1 $Date: Tue 2011-04-26 15:36:19 -0500$ ## EPICS Base built Jul 25 2012 ############################################################################ cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 45531, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) iocRun: All initialization complete ## Start any sequence programs seq pxlCooling,"user=sysuserHost" SEQ Version 2.0.12: Wed Jul 25 17:06:36 2012 Spawning state program "pxlCooling", thread 0x820b3b0: "pxlCooling" epics> On Thu, May 2, 2013 at 4:41 PM, James F Ross <[email protected]> wrote:
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
