1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer and registrars
Date: Thu, 2 May 2013 16:41:52 -0400
That did it.  Thanks!
James
On Thu, May 2, 2013 at 4:30 PM, Mark Rivers <[email protected]> wrote:
If your SNL program begins with a line like:
program pxlCooling(…
Then your registrar command is not quite right.  Rather than this:
registrar(pxlCooling_registrar)
it should be
registrar(pxlCoolingRegistrar)
From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
Sent: Thursday, May 02, 2013 3:08 PM
To: EPICS Tech Talk
Subject: sequencer and registrars
Hello all,
I'm adapting an IOC that reads text files and assigns the values in them to epics variables for a new system.  It uses sequencer and I don't think I'm setting up the registrar correctly in the dbd file...  I'm not very familiar with sequencer save for the .stt files build the binaries.  The old IOC was for a bunch of gas pressure and flow monitor variables for the time of flight detector at STAR.  I'm adapting a copy for a cooling system for a new pixel detector that will be installed soon.
I'm using epics base 3.13.12.1 and sequencer 2.0.12
The registrar in <top>/dbd/pxlCooling.dbd:
Here is the error I'm getting:
make[3]: Entering directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86'
/usr/bin/g++ -o pxlCooling  -L/home/sysuser/epics.3.14.12.1/base-3.14.12.1/lib/linux-x86 -L/home/sysuser/epics/synApps_5_5/support/seq-2-0-12/lib/linux-x86 -Wl,-rpath,/home/sysuser/epics.3.14.12.1/base-3.14.12.1/lib/linux-x86 -Wl,-rpath,/home/sysuser/epics/synApps_5_5/support/seq-2-0-12/lib/linux-x86       -m32               pxlCooling_registerRecordDeviceDriver.o pxlCooling.o pxlCoolingMain.o    -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
pxlCooling_registerRecordDeviceDriver.o: In function `pxlCooling_registerRecordDeviceDriver':
/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86/pxlCooling_registerRecordDeviceDriver.cpp:291: undefined reference to `pvar_func_pxlCooling_registrar'
collect2: ld returned 1 exit status
make[3]: *** [pxlCooling] Error 1
make[3]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp'
make: *** [pxlCoolingApp.install] Error 2
Thank you!
James Ross
Re: sequencer and registrars James F Ross
RE: sequencer and registrars Mark Rivers
Prev: RE: sequencer and registrars Mark Rivers
Next: Re: sequencer and registrars James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
