1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Would like to add regular expressions to dbpr
To: [email protected]
Date: Tue, 7 May 2013 13:45:38 -0500
Hi Mike,
On 2013-04-30 Zelazny, Michael Stanley wrote:
> Motivation: Currently the SLAC electron beam line controls group uses an
>  IRMIS crawler to get PV information into the RDB by crawling every IOCs
>  st.cmd.  Our engineers add new, but valid, syntax that results in us
>  having to massage that crawler quite a bit.  I would like to add a command
>  to all of our IOC startup scripts that generates a list of PVs and fields
>  that can easily crawled and inserted into the IRMIS RDB.  Example:
> iocshCmd("dbpr(*,5,1) >/data/iocInfo/IOC.pvEveryField")
> Opinions?
You can already use the command below on vxWorks to generate a .db file
containing all the non-default design-time field values of all record
instances currently loaded by the IOC:
    dbDumpRecord(pdbbase,0,0) > all.db
I think this should also work from RTEMS under CEXP, but iocsh doesn't have
any way of passing a NULL as the second argument (the record type name string)
which is currently necessary to dump all record types.  You'd have to issue
one command for each record type to use this command from iocsh with existing
versions of Base, although I will fix that to accept '*' or an empty string.
It should be relatively easy to create a new command to generate the output
that you asked for if dbDumpRecord doesn't work for you, although I'm not sure
that having an 'output format' argument is a good idea for user commands,
probably better to use a different command completely.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Re: Would like to add regular expressions to dbpr Benjamin Franksen
Would like to add regular expressions to dbpr Zelazny, Michael Stanley
Prev: CSS 3.1.x PVManager / JCA ClassCastException marcus . michalsky
Next: Re: Would like to add regular expressions to dbpr Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Would like to add regular expressions to dbpr Zelazny, Michael Stanley
