Am Dienstag, 7. Mai 2013, 20:45:38 schrieb Andrew Johnson:
> On 2013-04-30 Zelazny, Michael Stanley wrote:
> > Motivation: Currently the SLAC electron beam line controls group uses an
> > IRMIS crawler to get PV information into the RDB by crawling every IOCs
> > st.cmd. Our engineers add new, but valid, syntax that results in us
> > having to massage that crawler quite a bit. I would like to add a
> > command to all of our IOC startup scripts that generates a list of PVs
> > and fields
> > that can easily crawled and inserted into the IRMIS RDB. Example:
> > iocshCmd("dbpr(*,5,1) >/data/iocInfo/IOC.pvEveryField")
> > Opinions?
> You can already use the command below on vxWorks to generate a .db file
> containing all the non-default design-time field values of all record
> instances currently loaded by the IOC:
> dbDumpRecord(pdbbase,0,0) > all.db
> I think this should also work from RTEMS under CEXP, but iocsh doesn't have
> any way of passing a NULL as the second argument (the record type name
> string) which is currently necessary to dump all record types. You'd have
> to issue one command for each record type to use this command from iocsh
> with existing versions of Base, although I will fix that to accept '*' or
> an empty string.
BTW, it is a trivial exercise to add that to an existing installation without
modifying base by wrapping the dbDumpRecord in a C function (passing it NULL
pointers) and exporting this C function to the shell using the standard tools
(epicsExport.h, iocsh.h). No need to wait for the next base release... ;-)
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Would like to add regular expressions to dbpr Zelazny, Michael Stanley
- Re: Would like to add regular expressions to dbpr Andrew Johnson
RE: CSS 3.1.x PVManager / JCA ClassCastException Carcassi, Gabriele
<2013>
2025
2026
Thread Handle Leak: EPICS Base on Windows giles.knap
<2013>
2025
2026
