1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Regarding database links
To: Himanshu Tyagi <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 May 2013 14:08:53 +0000
You should be able to use the DISA and DISV fields to do what you want.  Here is an example:
record(longout, "$(P)$(R)FileNumber_write")
    field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
    field(DISV, "1")
    field(DTYP, "asynInt32")
    field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
So the SDIS field is a link to a field in another record.  Since DISV is 1 this means that this record will not process if $(P)$(R)FileNumber_Sync.PACT is 1.
From: [email protected] [[email protected]] on behalf of Himanshu Tyagi [[email protected]]
Sent: Wednesday, May 15, 2013 8:45 AM
To: [email protected]
Subject: Regarding database links
Can anyone guide me on enabling and disabling of epics Records. I want to use one PV whose value should control the processing of a second PV.
I know that there are certain epics field like DISA,DISV which can can be used to control the record processing but I am unable to use these.
Also i don;t know how the commands of dbPutLink are executed. THough it is very basic can any one help me on this part.
Thanks
Himanshu
Re: Regarding database links Pearson, Matthew R.
Regarding database links Himanshu Tyagi
Prev: How to output arrary data in EPICS db? Silver
Next: Open multiple OPI Lucas Jose Monteiro Carvalho
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Regarding database links Himanshu Tyagi
Next: Re: Regarding database links Pearson, Matthew R.
