1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Regarding database links
Date: Wed, 15 May 2013 10:24:01 -0400
There's also the DISP field, which will prevent a dbPutLink from changing a field. This can be useful if you don't want a field to change even when processing is disabled by using DISA/DISV.
Cheers,
Matt
On May 15, 2013, at 10:08 AM, Mark Rivers <[email protected]> wrote:
> You should be able to use the DISA and DISV fields to do what you want.  Here is an example:
> record(longout, "$(P)$(R)FileNumber_write")
>    field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
>    field(DISV, "1")
>    field(DTYP, "asynInt32")
>    field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
> So the SDIS field is a link to a field in another record.  Since DISV is 1 this means that this record will not process if $(P)$(R)FileNumber_Sync.PACT is 1.
> Mark
> ________________________________
> From: [email protected] [[email protected]] on behalf of Himanshu Tyagi [[email protected]]
> Sent: Wednesday, May 15, 2013 8:45 AM
> To: [email protected]
> Subject: Regarding database links
> Hi,
> Can anyone guide me on enabling and disabling of epics Records. I want to use one PV whose value should control the processing of a second PV.
> I know that there are certain epics field like DISA,DISV which can can be used to control the record processing but I am unable to use these.
> Also i don;t know how the commands of dbPutLink are executed. THough it is very basic can any one help me on this part.
> Thanks
> Himanshu
Regarding database links Himanshu Tyagi
RE: Regarding database links Mark Rivers
Prev: Open multiple OPI Lucas Jose Monteiro Carvalho
Next: Re: Open multiple OPI Hugo Slepicka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Regarding database links Mark Rivers
Next: How to output arrary data in EPICS db? Silver
