I am using the asynDriver R4-21 to run Mark River's areaDetectorR1-9-1
software on a Prosilica (i.e. Allied) GigE camera. Everything works
very well
except when the camera becomes offline (e.g. the Ethernet cable for the
Prosilica GigE camera is disconnected). Thankfully, the medm screen
indicated
the "disconnect" status when the Ethernet cable for the Prosilica GE
camera is
disconnected. However, one could still hit the 'acquire start/stop' and
other buttons
via the medm GUI and access the PVs.
One would wish to have a more detectable effect so that one could not
access
the camera's PVs, when the camera became offline. The attached patch
will disable
the PVs access, if the Ethernet cable for the GigE camera is
disconnected. If
the camera becomes online via Ethernet, the PVs will be accessible again.
The patch is tested with the GigE camera.
Cheers,
Kate Feng
--- asynRecord.c.orig 2012-12-21 17:34:45.000000000 -0500
+++ asynRecord.c 2013-05-16 13:41:37.651237452 -0400
@@ -874,12 +874,26 @@
asynPrint(pasynUser, ASYN_TRACE_FLOW,
"%s: exception %d\n",
pasynRec->name, (int) exception);
- if(callLock)
- dbScanLock((dbCommon *) pasynRec);
+ switch(exception) {
+ case asynExceptionConnect:
+ if ((pasynRec->cnct) && callLock) dbScanLock((dbCommon *) pasynRec);
+ break;
+ default:
+ if (callLock) dbScanLock((dbCommon *) pasynRec);
+ break;
/* There has been a change in connect or enable status */
monitorStatus(pasynRec);
- if(callLock)
- dbScanUnlock((dbCommon *) pasynRec);
+ if((pasynRec->cnct) && callLock) dbScanUnlock((dbCommon *) pasynRec);
+ break;
+ default:
+ if (callLock) dbScanUnlock((dbCommon *) pasynRec);
+ break;
static void queueTimeoutCallbackProcess(asynUser * pasynUser)
- RE: asynDriver R4-21: a possible patch for asynRecord.c: test on GigE camera Feng, Kate
Re: MEDM Eric Norum
Modbus Zenon Szalata
<2013>
2025
2026
Re: MEDM Eric Norum
<2013>
2025
2026
