1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 16 May 2013 11:38:00 -0700
Hi Mark,
I am still working on an IOC to control stepper motors with Beckhoff devices (KL2431 and KL2541). I am using your modbus (R2.2) support module. Beckhoff devices are called bus terminals. A bus terminal has two types of registers. One is a small set, typically 2 and in the case of the KL25x1 terminals 3, that one can read from or write to directly. Let's call them visible. The poll thread in modbus does IO to these registers. The other type is what I call "internal" or invisible registers. One can access these registers via the visible registers only. Hence, multiple operations need to be performed on the visible registers to either read from or write to an invisible register. I find that while I am writing to one of the invisible registers, at times the periodic reading from the visible registers in the poll thread, interferes with the writing process.
I assume that I can control the poll timeout using your poll_delay.template record. So, I am thinking that I need to change the poll timeout for the terminal I am trying to write to to "disable" poll reading from the terminal. I use seq records to sequence these read and write operations and I could add at the beginning of the sequence a request to set the timeout, to let's say 10 seconds, and at the end of the sequence restore the original timeout.
Is the thread woken up when a new timeout value is written out to the modbus module? Is there a better way to make sure that the poll reads do not interfere with the reading from and writing to the invisible registers?
Thanks Mark,
Zen
AW: Modbus Mathes, Hermann-Josef (IKP)
Prev: asynDriver R4-21: a possible patch for asynRecord.c: test on GigE camera Kate Feng
Next: fix for bug 1179642 Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynDriver R4-21: a possible patch for asynRecord.c: test on GigE camera Kate Feng
Next: AW: Modbus Mathes, Hermann-Josef (IKP)
