Hi Dan,
I am not familiar with RIO. Here at SLAC we are using Beckhoff for
number of different applications. We mostly use simple Beckhoff
devices, like ADC, DAC, digital IO, which are relatively easy to
deal with, in spite off that each of these modules has a number of
hidden registers. In these modules, hidden registers need to be
accessed only to change some configuration parameters. Recently,
one of the experimenters added Beckhoff stepper motor controllers.
In these devices, there are hidden registers that need to be
accessed frequently to monitor the position of the motor. There are
other hidden registers that also need to be accessed to set up the
motor motion. Because of all this, life became a bit more
difficult.
Thanks for your reply,
Zen
On 05/17/13 13:52, DJ Roberts wrote:
Hi Zen,
This is my first post to this tech-talk. I was surprised to
see that the Beckhoff hides much of its useful memory.
Have you tried a RIO? I recently used one and the whole
array table is read/write via modbus and all operations are
done in one modbus packet. I even wrote some embedded code to
store some interesting data in the array so I could get at it
via the modbus front end. Here's the one I used:
http://www.galilmc.com/products/rio-47xxx.php
-Dan
-------- Original Message
Hi Mark,
I am still working on an IOC to control stepper motors with Beckhoff
devices (KL2431 and KL2541). I am using your modbus (R2.2) support module.
Beckhoff devices are called bus terminals. A bus terminal has two types
of registers.
One is a small set, typically 2 and in the case of the KL25x1 terminals
3, that one can read from or write to directly. Let's call them
visible. The poll thread in modbus does IO to these registers.
The other type is what I call "internal" or invisible registers. One can
access these registers via the visible registers only. Hence, multiple
operations need to be performed on the visible registers to either read
from or write to an invisible register.
I find that while I am writing to one of the invisible registers, at
times the periodic reading from the visible registers in the poll
thread, interferes with the writing process.
I assume that I can control the poll timeout using your
poll_delay.template record.
So, I am thinking that I need to change the poll timeout for the
terminal I am trying to write to to "disable" poll reading from the
terminal. I use seq records to sequence these read and write operations
and I could add at the beginning of the sequence a request to set the
timeout, to let's say 10 seconds, and at the end of the sequence restore
the original timeout.
Is the thread woken up when a new timeout value is written out to the
modbus module?
Is there a better way to make sure that the poll reads do not interfere
with the reading from and writing to the invisible registers?
Thanks Mark,
Zen
- Re: Fwd: Modbus DJ Roberts
Re: AW: Modbus Zenon Szalata
More on Modbus Zenon Szalata
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
