1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error in installing asyn driver
To: nalaka samarasinghe <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Mon, 20 May 2013 17:24:14 +0000
Hi Nalaka,
I am not familiar with that error, so I am including tech-talk in the reply.  I suspect perhaps the problem is that you are using a rather old version of EPICS base (3.14.10) and a new version of the gcc compiler on Ubuntu 12.04.  Is it possible for you to upgrade to base 3.14.12.3 and see if that fixes the problem?
Sent: Monday, May 20, 2013 11:05 AM
To: Mark Rivers
Subject: Re: Error in installing asyn driver
Hi Mark,
I am trying to install EPICS 3.14.10  on ubuntu 12.04. Is there any additional libraries we need to install ? I did all library installations done for ubuntu 10.04 LTS. But, following error appears during building process
Start:
 ake[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/libCom/O.linux-x86'
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/libCom'
make -C ./toolsComm install
make[2]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm'
make -C ./antelope install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[4]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope/O.linux-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope/O.linux-x86'
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope'
make -C ./flex install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex'
make[4]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex/O.linux-x86'
make[4]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex/O.linux-x86'
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex'
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm'
make -C ./ca install
make[2]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include         ../cac.cpp
In file included from ../cac.cpp:37:0:
../cac.h:259:26: error: reference ‘mutex’ cannot be declared ‘mutable’ [-fpermissive]
../cac.h:260:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’ [-fpermissive]
In file included from ../cac.cpp:45:0:
../udpiiu.h:126:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’ [-fpermissive]
../udpiiu.h:127:26: error: reference ‘cacMutex’ cannot be declared ‘mutable’ [-fpermissive]
make[3]: *** [cac.o] Error 1
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca'
make[1]: *** [ca.install] Error 2
make[1]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src'
make: *** [src.install] Error 2
nalakasa@ubuntu:~/opt/epics/base$
END.
Could you please help me figure out what this means ?
With Best Regards,
Nalaka
On Sat, May 18, 2013 at 11:59 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
The two computers just need to be on the same subnet.  So their addresses must match in the "subnet mask" bits, and be different in the other bits.
The medm on the second computer will send a broadcast message on the network, asking what computer has each PV.  The first computer will reply that it hosts the PV, and they will establish a connection.
From: nalaka samarasinghe [[email protected]<mailto:[email protected]>]
Sent: Thursday, May 16, 2013 10:28 PM
To: Mark Rivers
Hi Mark,
Hope that you are doing well! While working with i wanted to use bit of networking also. That is , when i connect the hardware to my Laptop where the EPICS has been installed and running, i need to connect another computer through a cross cable and run MEDM client on the second computer to control the hardware connected to the first laptop.
I have already connected both computers on the network and running. How can i set the IP address of the IOC on the laptop  so that the MEDM client on the 2nd computer  can communicate  with that ? If you can give me some documents or some sources to learn about this,I would be very thankful to you.
Thanks & Regards,
Nalaka
From: nalaka samarasinghe [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>]
Sent: Thursday, January 10, 2013 12:28 PM
To: Mark Rivers
Hi Mark,
Can you pls let me know what you understand by the following output when i set the scantime
1
2013/01/10 23:52:47.074 PS1 read
1
2013/01/10 23:52:47.074 /dev/ttyUSB0 read.
2013/01/10 23:52:47.080 /dev/ttyUSB0 read 1
7
2013/01/10 23:52:47.080 /dev/ttyUSB0 read 1, return 0
2013/01/10 23:52:47.080 PS1 read
7
2013/01/10 23:52:47.080 /dev/ttyUSB0 read.
2013/01/10 23:52:47.085 /dev/ttyUSB0 read 1
\r
2013/01/10 23:52:47.085 /dev/ttyUSB0 read 1, return 0
2013/01/10 23:52:47.085 PS1 read
\r
2013/01/10 23:52:47.085 /dev/ttyUSB0 read.
2013/01/10 23:52:47.089 /dev/ttyUSB0 read 1
\n
2013/01/10 23:52:47.089 /dev/ttyUSB0 read 1, return 0
2013/01/10 23:52:47.089 PS1 read
\n
2013/01/10 23:52:47.089 PS1 temp_val1: Input "T17<0d>" mismatch after 1 byte
2013/01/10 23:52:47.089 PS1 temp_val1: got "17<0d>" where " " was expected
On Thu, Jan 10, 2013 at 9:34 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>> wrote:
I don't understand why it is sending CR LF. The proto file you sent me previously had both input and output terminators only CR, not CR LF.  And your startup script is not setting terminators at all, right?  You have no commands like asynOctetSetInputEos or asynOctetSetOutputEos?
I would recommend removing the terminator commands from the proto file.  Add the command asynOctetSetInputEos to your startup script.  Don't add asynOctetSetOutputEos since you don't need output terminators for your device.
But this probably does not explain why your device appears to be sending nothing to EPICS.  The EPICS serial port driver is reporting that it has received 0 characters in 1 second.
From: nalaka samarasinghe [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>]
Sent: Wednesday, January 09, 2013 9:21 PM
To: Mark Rivers
Hi Mark,
It is not necessary. Can i send the charactors without CR LF? Can that solve the problem ?
Best Regards,
Nalaka
On Wed, Jan 9, 2013 at 12:59 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
The output you sent shows that your ai record is processing, but the read is timing out, it is not receiving anything.
Here is a complete “cycle”.
2013/01/08 22:58:29.285 PS1 set Eos 0
2013/01/08 22:58:30.181 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:30.182 PS1 schedule queueRequest timeout
2013/01/08 22:58:30.182 PS1 callback
2013/01/08 22:58:30.182 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:30.182 PS1 flush
2013/01/08 22:58:30.182 /dev/ttyUSB0 flush
2013/01/08 22:58:30.182 PS1 get Eos 0
2013/01/08 22:58:30.182 PS1 set Eos 0
2013/01/08 22:58:30.182 /dev/ttyUSB0 write.
2013/01/08 22:58:30.182 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:30.182 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:30.182 PS1 wrote
t?\r\n
2013/01/08 22:58:30.182 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:30.182 PS1 set Eos 2
\r\n
2013/01/08 22:58:30.182 /dev/ttyUSB0 read.
2013/01/08 22:58:31.177 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:31.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:31.281 PS1 temp_val1: No reply from device within 1000 ms
EPICS thinks it has successfully sent the string “t?\r\n”.
It then reads from the device, at time 30.182.  However, at time 31.177 (1 second later) the read timed out.
These lines mean that no characters arrived from the device (“read 0”) and the it timed out (“return 1”).
So for some reason your device does not appear to be sending data back to the host when it receives the t?\r\n command.
Perhaps there is something wrong with the baud, parity, stop bits, etc. that is causing your device not to recognize the t? command and so it is not sending back a response?
Does your device actually want to receive a \r\n after the t? command, and does it send a \r\n after the temperature?
From: nalaka samarasinghe [mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>]
Sent: Tuesday, January 08, 2013 11:51 AM
To: Mark Rivers
Hi Mark ,
Please see the output at the start and when running
nalaka@nalaka-laptop:~$ cd ledlight/
nalaka@nalaka-laptop:~/ledlight$ cd iocBoot/
nalaka@nalaka-laptop:~/ledlight/iocBoot$ cd iocpsupplyIOC/
nalaka@nalaka-laptop:~/ledlight/iocBoot/iocpsupplyIOC$ /home/nalaka/ledlight/bin/linux-x86/psupply st.cmd
#!../../bin/linux-x86/psupply
## You may have to change psupply to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocpsupplyIOC")
epicsEnvSet("TOP","/home/nalaka/ledlight")
epicsEnvSet("SNCSEQ","/home/nalaka/opt1/epics/sequencer1")
epicsEnvSet("EPICS_BASE","/home/nalaka/opt1/epics/base")
epicsEnvSet("ASYN","/home/nalaka/opt1/epics/modules/asyn")
epicsEnvSet("STREAM_PROTOCOL_PATH","./protocols")
cd /home/nalaka/ledlight
dbLoadDatabase "dbd/psupply.dbd"
psupply_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadRecords("db/psupp.db","user=nalakaHost")
 drvAsynSerialPortConfigure("PS1","/dev/ttyUSB0")
# Enable ASYN_TRACEIO_ESCAPE
asynSetTraceIOMask("PS1",0,2)
# Enable ASYN_TRACE_ERROR, ASYN_TRACEIO_DRIVER, and ASYN_TRACE_FLOW
asynSetTraceMask("PS1",0,0xff)
2013/01/08 22:58:27.141 PS1 -1 exception 3 occurred calling exceptionUser
asynSetOption("PS1",0,"baud","2400")
2013/01/08 22:58:27.141 PS1 addr -1 queueRequest priority 3 not lockHolder
2013/01/08 22:58:27.141 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:27.141 asynManager connect queueCallback port:PS1
2013/01/08 22:58:27.141 Open connection to /dev/ttyUSB0
2013/01/08 22:58:27.161 Opened connection to /dev/ttyUSB0
2013/01/08 22:58:27.161 PS1 -1 exception 0 occurred calling exceptionUser
2013/01/08 22:58:27.161 asynManager connect queueCallback port:PS1
2013/01/08 22:58:27.161 PS1 callback
2013/01/08 22:58:27.161 PS1 setOption key baud val 2400
asynSetOption("PS1",0,"bits","8")
2013/01/08 22:58:27.164 PS1 addr -1 queueRequest priority 0 not lockHolder
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Dec 20 2012
## Start any sequence programs
#seq sncxxx,"user=nalakaHost"
epics> 2013/01/08 22:58:28.181 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:28.181 PS1 schedule queueRequest timeout
2013/01/08 22:58:28.181 PS1 callback
2013/01/08 22:58:28.182 PS1 flush
2013/01/08 22:58:28.182 /dev/ttyUSB0 flush
2013/01/08 22:58:28.182 PS1 get Eos 0
2013/01/08 22:58:28.182 PS1 set Eos 0
2013/01/08 22:58:28.182 /dev/ttyUSB0 write.
2013/01/08 22:58:28.182 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:28.182 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:28.182 PS1 wrote
t?\r\n
2013/01/08 22:58:28.182 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:28.182 PS1 schedule queueRequest timeout
2013/01/08 22:58:28.182 PS1 callback
2013/01/08 22:58:28.182 PS1 set Eos 2
\r\n
2013/01/08 22:58:28.182 /dev/ttyUSB0 read.
2013/01/08 22:58:29.181 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:29.285 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:29.285 PS1 temp_val1: No reply from device within 1000 ms
t?\r\n
t?\r\n
\r\n
2013/01/08 22:58:31.281 PS1 set Eos 0
2013/01/08 22:58:32.182 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:32.182 PS1 schedule queueRequest timeout
2013/01/08 22:58:32.182 PS1 callback
2013/01/08 22:58:32.182 PS1 flush
2013/01/08 22:58:32.182 /dev/ttyUSB0 flush
2013/01/08 22:58:32.182 PS1 get Eos 0
2013/01/08 22:58:32.182 PS1 set Eos 0
2013/01/08 22:58:32.182 /dev/ttyUSB0 write.
2013/01/08 22:58:32.182 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:32.182 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:32.182 PS1 wrote
t?\r\n
2013/01/08 22:58:32.182 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:32.183 PS1 set Eos 2
\r\n
2013/01/08 22:58:32.183 /dev/ttyUSB0 read.
2013/01/08 22:58:33.178 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:33.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:33.281 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 22:58:33.281 PS1 set Eos 0
2013/01/08 22:58:34.182 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:34.182 PS1 schedule queueRequest timeout
2013/01/08 22:58:34.182 PS1 callback
2013/01/08 22:58:34.183 PS1 callback
2013/01/08 22:58:34.183 PS1 flush
2013/01/08 22:58:34.183 /dev/ttyUSB0 flush
2013/01/08 22:58:34.183 PS1 get Eos 0
2013/01/08 22:58:34.183 PS1 set Eos 0
2013/01/08 22:58:34.183 /dev/ttyUSB0 write.
2013/01/08 22:58:34.183 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:34.183 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:34.183 PS1 wrote
t?\r\n
2013/01/08 22:58:34.183 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:34.183 PS1 schedule queueRequest timeout
2013/01/08 22:58:34.183 PS1 set Eos 2
\r\n
2013/01/08 22:58:34.183 /dev/ttyUSB0 read.
2013/01/08 22:58:35.178 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:35.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:35.281 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 22:58:35.281 PS1 set Eos 0
2013/01/08 22:58:36.183 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:36.183 PS1 schedule queueRequest timeout
2013/01/08 22:58:36.183 PS1 callback
2013/01/08 22:58:36.183 PS1 flush
2013/01/08 22:58:36.183 /dev/ttyUSB0 flush
2013/01/08 22:58:36.183 PS1 get Eos 0
2013/01/08 22:58:36.183 PS1 set Eos 0
2013/01/08 22:58:36.183 /dev/ttyUSB0 write.
2013/01/08 22:58:36.183 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:36.183 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:36.183 PS1 wrote
t?\r\n
2013/01/08 22:58:36.183 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:36.183 PS1 set Eos 2
\r\n
2013/01/08 22:58:36.183 /dev/ttyUSB0 read.
2013/01/08 22:58:37.179 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:37.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:37.281 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 22:58:37.281 PS1 set Eos 0
2013/01/08 22:58:38.183 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:38.183 PS1 schedule queueRequest timeout
2013/01/08 22:58:38.183 PS1 callback
2013/01/08 22:58:38.183 PS1 flush
2013/01/08 22:58:38.183 /dev/ttyUSB0 flush
2013/01/08 22:58:38.183 PS1 get Eos 0
2013/01/08 22:58:38.183 PS1 set Eos 0
2013/01/08 22:58:38.183 /dev/ttyUSB0 write.
2013/01/08 22:58:38.183 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:38.183 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:38.184 PS1 wrote
t?\r\n
2013/01/08 22:58:38.184 PS1 set Eos 0
2013/01/08 22:58:38.184 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:38.184 PS1 schedule queueRequest timeout
2013/01/08 22:58:38.184 PS1 callback
2013/01/08 22:58:38.184 PS1 get Eos 0
2013/01/08 22:58:38.184 PS1 set Eos 2
\r\n
2013/01/08 22:58:38.184 /dev/ttyUSB0 read.
2013/01/08 22:58:39.179 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:39.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:39.281 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 22:58:39.281 PS1 set Eos 0
2013/01/08 22:58:40.183 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:40.183 PS1 schedule queueRequest timeout
2013/01/08 22:58:40.184 PS1 callback
2013/01/08 22:58:40.184 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:40.184 PS1 schedule queueRequest timeout
2013/01/08 22:58:40.184 PS1 flush
2013/01/08 22:58:40.184 /dev/ttyUSB0 flush
2013/01/08 22:58:40.184 PS1 get Eos 0
2013/01/08 22:58:40.184 PS1 set Eos 0
2013/01/08 22:58:40.184 /dev/ttyUSB0 write.
2013/01/08 22:58:40.184 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 22:58:40.184 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 22:58:40.184 PS1 wrote
t?\r\n
2013/01/08 22:58:40.184 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 22:58:40.184 PS1 set Eos 2
\r\n
2013/01/08 22:58:40.184 /dev/ttyUSB0 read.
2013/01/08 22:58:41.179 /dev/ttyUSB0 timeout handler.
2013/01/08 22:58:41.281 /dev/ttyUSB0 read 0, return 1
2013/01/08 22:58:41.281 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 22:58:41.281 PS1 set Eos 0
2013/01/08 22:58:42.184 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 22:58:42.184 PS1 schedule queueRequest timeout
2013/01/08 22:58:42.184 PS1 callback
2013/01/08 22:58:42.184 PS1 flush
2013/01/08 22:58:42.184 /dev/ttyUSB0 flush
2013/01/08 22:58:42.184 PS1 get Eos 0
2013/01/08 22:58:42.184 PS1 set Eos 0
2013/01/08 22:58:42.184 /dev/ttyUSB0 write.
2013/01/08 22:58:42.184 /dev/ttyUSB0 write 4
t?\r\n
when doing a Caput
2013/01/08 23:18:00.857 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 23:18:00.857 PS1 set Eos 0
2013/01/08 23:18:01.757 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 23:18:01.757 PS1 schedule queueRequest timeout
2013/01/08 23:18:01.757 PS1 callback
2013/01/08 23:18:01.757 PS1 flush
2013/01/08 23:18:01.757 /dev/ttyUSB0 flush
2013/01/08 23:18:01.757 PS1 get Eos 0
2013/01/08 23:18:01.757 PS1 set Eos 0
2013/01/08 23:18:01.757 /dev/ttyUSB0 write.
2013/01/08 23:18:01.757 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 23:18:01.757 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 23:18:01.757 PS1 wrote
t?\r\n
2013/01/08 23:18:01.757 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 23:18:01.757 PS1 set Eos 2
\r\n
2013/01/08 23:18:01.757 /dev/ttyUSB0 read.
2013/01/08 23:18:02.753 /dev/ttyUSB0 timeout handler.
2013/01/08 23:18:02.857 /dev/ttyUSB0 read 0, return 1
2013/01/08 23:18:02.857 PS1 temp_val1: No reply from device within 1000 ms
2013/01/08 23:18:02.857 PS1 set Eos 0
2013/01/08 23:18:03.757 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/08 23:18:03.757 PS1 schedule queueRequest timeout
2013/01/08 23:18:03.757 PS1 callback
2013/01/08 23:18:03.757 PS1 flush
2013/01/08 23:18:03.757 /dev/ttyUSB0 flush
2013/01/08 23:18:03.757 PS1 get Eos 0
2013/01/08 23:18:03.757 PS1 set Eos 0
2013/01/08 23:18:03.757 /dev/ttyUSB0 write.
2013/01/08 23:18:03.757 /dev/ttyUSB0 write 4
t?\r\n
2013/01/08 23:18:03.757 wrote 4 to /dev/ttyUSB0, return asynSuccess
2013/01/08 23:18:03.757 PS1 wrote
t?\r\n
2013/01/08 23:18:03.757 PS1 addr -1 queueRequest priority 0 from lockHolder
2013/01/08 23:18:03.758 PS1 schedule queueRequest timeout
2013/01/08 23:18:03.758 PS1 callback
2013/01/08 23:18:03.758 PS1 get Eos 0
2013/01/08 23:18:03.758 PS1 set Eos 2
\r\n
2013/01/08 23:18:03.758 /dev/ttyUSB0 read.
2013/01/08 23:18:04.753 /dev/ttyUSB0 timeout handler.
2013/01/08 23:18:04.857 /dev/ttyUSB0 read 0, return 1
On Tue, Jan 8, 2013 at 10:32 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
Again, please send the complete output when you start the IOC, for a short time afterwards, and then when you do the caput.  Do this with asynTraceMask=0xff.  The records “block” until they are complete.  In other words the output records (ao) will lock the serial port until the write is complete, and the input records (ai) will lock the port until the read is complete or times out.  But you will see a message on the IOC console even if the read times out as long as the record is processing correctly.
Sent: Tuesday, January 08, 2013 10:53 AM
To: Mark Rivers
Hi Mark,
I see the charactors when i send data. However, only incoming data that i cannot see. Is this like one way communication. Can the records read and write data at the same time ? when i try to see the incoming data only 0 value is displayed.
Thanks  & Regards,
Nalaka
On Mon, Jan 7, 2013 at 11:32 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
I see your problem.  You got an error when loading your .db file:
Can't set "PS1:temp_val1.SCAN" to ".1 second "
Error at or before ")" in file "db/psupp.db" line 12
The problem is this line in your .db file:
field(SCAN,".1 second ")
You have a trailing space after “second”, you need to delete that space.
>  when i do caput, following output is displayed
nalaka@nalaka-laptop:~$ caput temp_val "5"
Old : temp_val                       2
New : temp_val                       5
There should also have been some output displayed in the IOC window that shows the characters sent to the device.
Sent: Monday, January 07, 2013 10:12 AM
To: Mark Rivers
Hi Mark,
I have modified the Microcontroller program as follows.
when i enter value 1  on keyboard   ON1 will be sent through the PORT and when entering 0  OFF0 will be sent.when pressing t  it will send temperature as ( e.g. T26  26-temp value)
When running the IOC , following output will be displayed
*************************************************************Start
< envPaths
 drvAsynSerialPortConfigure("PS1","/dev/ttyUSB1")
2013/01/07 21:25:55.661 PS1 -1 exception 3 occurred calling exceptionUser
2013/01/07 21:25:55.661 PS1 addr -1 queueRequest priority 3 not lockHolder
2013/01/07 21:25:55.661 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.680 Opened connection to /dev/ttyUSB1
2013/01/07 21:25:55.680 PS1 -1 exception 0 occurred calling exceptionUser
2013/01/07 21:25:55.680 asynManager connect queueCallback port:PS1
2013/01/07 21:25:55.681 PS1 callback
2013/01/07 21:25:55.681 PS1 setOption key baud val 2400
2013/01/07 21:25:55.684 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.684 PS1 callback
2013/01/07 21:25:55.684 PS1 setOption key bits val 8
asynSetOption("PS1",0,"parity","none")
2013/01/07 21:25:55.686 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.686 PS1 callback
2013/01/07 21:25:55.686 PS1 setOption key parity val none
asynSetOption("PS1",0,"stop","1")
2013/01/07 21:25:55.689 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.689 PS1 callback
2013/01/07 21:25:55.689 PS1 setOption key stop val 1
asynSetOption("PS1",0,"clocal","Y")
2013/01/07 21:25:55.692 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.692 PS1 callback
2013/01/07 21:25:55.692 PS1 setOption key clocal val Y
asynSetOption("PS1",0,"crtscts","N")
2013/01/07 21:25:55.695 PS1 addr -1 queueRequest priority 0 not lockHolder
2013/01/07 21:25:55.695 PS1 callback
2013/01/07 21:25:55.695 PS1 setOption key crtscts val N
cd /home/nalaka/ledlight/iocBoot/iocpsupplyIOC
iocInit
Starting iocInit
epics>
*************************************************************END
When running the IOC there is no realtime output being displayed as you said.
Old : temp_val                       2
New : temp_val                       5
a0 records work and only problem is with ai records
when using caget to display temperature
nalaka@nalaka-laptop:~$ caget temp_val1
Channel connect timed out: 'temp_val1' not found.
For your  information I will attach  the db file and proto file also
bd file
start.....................
record(ao, "temp_val") {
  field(DTYP,"stream")
  field(OUT,"@psupp.proto putnumber PS1")
record(ai, "PS1:temp_val1") {
  field(INP,"@psupp.proto getnumber PS1")
record(bo,"switch"){
field(ZNAM,"off")
field(ONAM,"on")
End.........................................................
Proto file start..............................................
OutTerminator = CR LF;
InTerminator = CR LF;
putnumber {
  out "%d";
getnumber {
out "t?";
 in "T%d";
ExtraInput=Ignore;
switch1 {
out "0";
in "OFF%d";
out "1";
in "ON%d";
Proto file End.........................................
Thanks & Best Regards,
Nalaka
On Mon, Jan 7, 2013 at 12:01 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
You should be aware that doing a caget will not cause any I/O from the device, it only returns the current value in the record to the client.  So doing a caget will not cause any messages.  However, your ai record is processing every 0.1 second, and that should cause a message to be printed every time it runs, even if the device does not send any data.
Please change this line:
asynSetTraceMask("PS1",0,0x19)
to this:
That will turn on even more debugging, including that from device support.
Please send me the complete output when the IOC starts up, and runs for a little while.  Also send the output when you do a caput.
From: nalaka samarasinghe [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>]
Sent: Sunday, January 06, 2013 10:53 AM
To: Mark Rivers
Hi Mark,
You are correct. This device transmits the messages constantly not on request. My circuit has a seven segment display and ,I have written the firmware of the Micro controller such that , when i send the key strokes from 0 to 9 the seven segment display will display it.Right after M is the ASCII representation of the key stroke.
"T %*d %*d %d";  : Reason for this is that i thought the there can be null characters preceding the value and to ignore them ,i wrote the code that way.(which is not correct)
after modifying the start-up script and it does not show the messages constantly . when trying to use caput command it will show the messages. When trying to get temperature readings it does not display any messages.
But i did not get any error messages when running the IOC before. Can we retrieve data from continuously recieving string like this?
Nalaka
On Sun, Jan 6, 2013 at 8:03 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 u<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>> wrote:
Hi Nalaka,
Does your device send messages constantly, or only when you send it a request?  It looks like it sends them constantly.  It also appears to send 2 kinds of messages, those starting with M (what are those?) and those starting with T (temperature).
It seems like your getnumber protocol is wrong, it should just be:
getnumber {
 in "T %d";
Why did you use "T %*d %*d %d";
When you run the IOC are you getting error messages from streamDevice?  I think you should be, since it will sometimes get the M messages.
You should turn on asynTrace to see if EPICS is getting the messages from the device.  Modify your startup script as follows:
drvAsynSerialPortConfigure("PS1","/dev/ttyS0")
Now you should see messages when characters are read from the device.
From: nalaka samarasinghe [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>]
Sent: Sunday, January 06, 2013 4:11 AM
To: Mark Rivers
Hi Mark,
I have connected a temperature sensor to my circuit and get the temperature values serialy.This is how it is seen on the GTKterm
M13
T18
M13
T18
M13
T18
M13
T18
M13
T18
M13
T18
My Proto file is below
OutTerminator = CR;
InTerminator = CR;
putnumber {
  out "%d";
getnumber {
 in "T %*d %*d %d";
My Database file is below
record(ai, "temp_val1") {
  field(SCAN,"0.1 second")
When i try to get the value of temperature sensor  it returns only zero.
Temperature value is given just after every T
Please let me know where i have gone wrong.
Nalaka
From: nalaka samarasinghe [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:nalaka1!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>]
Sent: Saturday, January 05, 2013 8:21 PM
To: Mark Rivers
Hi Mark,
My Data acquisition system is working. Many thanks for the support.
With Best Regards,
Nalaka
On Sun, Jan 6, 2013 at 6:38 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 u<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 du<mailto:[email protected]>><mailto:[email protected]!
 go.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 cago.edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]!
 hicago.edu<mailto:[email protected]><mailto:[email protected]!
 .edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>> wrote:
Your first problem is on this line:
 drvAsynSerialPortConfigure("PS1","/dev/ttyS0") #This command initializes the serial port communication between power supply and serial port COM1
st.cmd -- Line 18 -- Illegal integer `#This'
Note that you got an error message because you put a comment on the same line.  Move the comment to its own line and then see if asyn port PS1 is created properly.
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:nalaka1020!
 @gmail.com>><mailto:[email protected]<mailto:nalaka1020@gma!
 il.com><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]!
 om>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>]
Sent: Saturday, January 05, 2013 7:06 PM
To: Mark Rivers
Hi Mark,
Please find the error code appearing below.
Start:
< envPaths
epicsEnvSet("STREAM_PROTOCOL_PATH","home/nalaka/ledlight/iocBoot/iocpsupplyIOC/protocols")
#the following serial communication settings are according to the User Manual
asynSetOption("PS1",0,"baud","2400") #baud rate setting (bits per second)
connectDevice failed asynManager:connectDevice port PS1 not found
asynSetOption("PS1",0,"bits","8") #number of data bits
asynSetOption("PS1",0,"parity","none") #no parity bit
asynSetOption("PS1",0,"stop","1") #number of STOP bits
asynSetOption("PS1",0,"clocal","Y") #do not use local clock
asynSetOption("PS1",0,"crtscts","N") #?
iocInit
Starting iocInit
2013/01/06 06:27:24.915 _main_ Businterface 'PS1' not found for 'temp_val'
2013/01/06 06:27:24.915 _main_ temp_val: Can't attach to bus PS1 -1
2013/01/06 06:27:24.915 _main_ temp_val: Record initialization failed
Bad init_rec return value  PV: temp_val ao: init_record
epics> #seq sncxxx,"user=nalakaHost"2013/01/06 06:27:41.891 CAS-client temp_val: Record not initialised correctly
2013/01/06 06:27:55.454 CAS-client temp_val: Record not initialised correctly
End:
On Sun, Jan 6, 2013 at 6:20 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 .edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]!
 cago.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 cago.edu<mailto:[email protected]>>><mailto:[email protected]!
 .edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 o.edu<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 u<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>>> wrote:
Please send the complete output when you start the IOC.  The text in your message and the screen shot was just the end of the output.  I need to see the complete output, because I believe the main error occurred earlier.
 om>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]!
 om><mailto:[email protected]<mailto:[email protected]>><mailto:na!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:nalaka!
 [email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:nalaka!
 <mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<ma!
 ilto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>>]
Sent: Saturday, January 05, 2013 5:00 AM
To: Mark Rivers
Hi Mark,
Please see  the error appearing when trying to run the ioc.
What does that mean?
Thanks & Kind Regards
Nalaka
iocInit
Starting iocInit
2013/01/05 16:16:44.730 _main_ Businterface 'PS1' not found for 'temp_val'
2013/01/05 16:16:44.730 _main_ temp_val: Can't attach to bus PS1 -1
2013/01/05 16:16:44.730 _main_ temp_val: Record initialization failed
The CA server's beacon address list was empty after initialization?
epics>
On Sat, Jan 5, 2013 at 12:49 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 du<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected].!
 edu<mailto:[email protected]>><mailto:[email protected]!
 ago.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 icago.edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]!
 chicago.edu<mailto:[email protected]><mailto:[email protected]!
 o.edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]!
 icago.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 icago.edu<mailto:[email protected]>>><mailto:[email protected]!
 o.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 go.edu<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 du<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 ago.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 cago.edu<mailto:[email protected]>><mailto:[email protected].!
 edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 o.edu<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]!
 u<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]!
 o.edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 .edu<mailto:[email protected]>>>><mailto:[email protected]!
 u<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 u<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected].!
 edu<mailto:[email protected]><mailto:[email protected]<ma!
 ilto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>>>> wrote:
The easiest way to do this is to use the streamDevice package.
http://epics.web.psi.ch/software/streamdevice/
For streamDevice you will create a “protocol” file that defines the syntax to send a command to the device and parse the response.  You then build an IOC with both asyn and streamDevice, build a database file that uses your protocol file, and make an medm screen.
There are some examples in the tests directory that comes with streamDevice:
stream/streamDevice/streamApp/tests
Here is a simple protocol file for an Omega meter:
corvette:ip/ipApp/Db>more Omega_DP41.proto
# Omega_DP41.proto
# stream protocol file for Omega DP41 series meters
# Mark Rivers
# May 4, 2007
OutTerminator = CR;
InTerminator = CR;
PREFIX = *;
readUnfiltered {
   out "\${PREFIX}X01";
   in "X01%f";
Here is the database that uses that protocol:
record(ai,"$(P)$(R)Unfiltered") {
    field(DTYP, "stream")
    field(INP, "@Omega_DP41.proto readUnfiltered $(PORT)")
    field(HOPR, "$(HOPR)")
    field(LOPR, "$(LOPR)")
    field(PREC, "$(PREC)")
    field(EGU,  "$(EGU)")
What specifically did you have problems with in making the IOC.
From: nalaka samarasinghe [mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:nal!
 [email protected]>><mailto:[email protected]<mailto:nalaka1!
 [email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:nalaka1020@!
 gmail.com>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:nalaka1020@!
 gmail.com><mailto:[email protected]<mailto:[email protected]>><ma!
 ilto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto!
 :[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto!
 :[email protected]<mailto:[email protected]><mailto:nalaka1020@gm!
 ail.com<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:nalaka1020@gmail!
 .com<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:nalaka1020@gmail.!
 com<mailto:[email protected]>>><mailto:[email protected]<mailto:n!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:nalak!
 [email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:nalaka1!
 [email protected]><mailto:[email protected]<mailto:[email protected]>!
 >>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]!
 m><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><!
 mailto:[email protected]<mailto:[email protected]><mailto:nalaka1!
 [email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:nalaka10!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:nalaka1020@g!
 mail.com<mailto:[email protected]>><mailto:[email protected]<mail!
 to:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>>>]
Sent: Friday, January 04, 2013 11:55 AM
To: Mark Rivers
Subject: Re: Error in installing asyn driver
Hi Mark,
I am connecting a PIC MCU Based circuit where it sends some temperature values through serial port(RS232).I need to display the Temperature Values on MEDM GUI. Please let me know how i can do it. I installed asyn driver already and i have some problems in making a IOC suitable for the said application. Please help me on this.Any documentation would be great.
Thanks & Kind Regards,
Nalaka
On Thu, Jan 3, 2013 at 2:07 AM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 ago.edu<mailto:[email protected]>><mailto:[email protected]!
 .edu<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected].!
 <mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]!
 du<mailto:[email protected]><mailto:[email protected]<mai!
Hi Nalaka,
You have 2 choices to avoid that error:
1) Do what Keith suggested, install the sequencer package and edit configure/RELEASE to point to it.
2) Comment out the line in configure/RELEASE that defines SNCSEQ by placing a "#" character at the start, like the following:
#SNCSEQ=$(SUPPORT)/seq-2-1-10
If you do that and then run "make" at the top-level in asyn it will not build the testIPServerApp directory, and you will not get the error.
-----Original Message-----
From: [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailt!
 o:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailt!
 nl.gov><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]!
 l.gov>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]!
 nl.gov><mailto:[email protected]<mailto:tech-talk-bounces@a!
 ps.anl.gov>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:tech-talk-bounces!
 @aps.anl.gov><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech-talk-bounces@ap!
 s.anl.gov>>>>><mailto:[email protected]<mailto:tech-talk-bo!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech-talk-bounc!
 [email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:tech-talk-boun!
 [email protected]><mailto:[email protected]<mailto:tech-talk-!
 [email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:tech-talk!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech-tal!
 [email protected]>><mailto:[email protected]<mailto:tec!
 [email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech!
 [email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:te!
 [email protected]><mailto:[email protected]<mailt!
 o:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:!
 [email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:t!
 [email protected]>>><mailto:[email protected]<ma!
 ilto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<m!
 ailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<ma!
 v<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected].!
 gov<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 ov<mailto:[email protected]>><mailto:tech-talk-bounces@aps.!
 anl.gov<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]!
 .gov<mailto:[email protected]>>>>>>>>> [mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:tech-talk-bounces@a!
 ps.anl.gov<mailto:[email protected]><mailto:tech-talk-bounc!
 [email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:tech-talk-bounc!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:tech-talk-bounce!
 [email protected]<mailto:[email protected]>>>><mailto:tech-talk!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:tech-talk-b!
 [email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:tech-talk!
 [email protected]<mailto:[email protected]><mailto:tech-!
 [email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:tech!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:tech-ta!
 [email protected]<mailto:[email protected]>><mailto:te!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:te!
 [email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:t!
 [email protected]<mailto:[email protected]><mail!
 to:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><ma!
 ilto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mai!
 >><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]!
 v><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>!
 <mailto:[email protected]<mailto:[email protected].!
 gov><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]!
 ov>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]!
 l.gov><mailto:[email protected]<mailto:tech-talk-bounces@ap!
 s.anl.gov>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:tech-talk-bounces@aps!
 .anl.gov><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech-talk-bounces@aps!
 .anl.gov>>><mailto:[email protected]<mailto:tech-talk-bounc!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:tech-talk-bounce!
 [email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:tech-talk-bounces@!
 aps.anl.gov><mailto:[email protected]<mailto:tech-talk-boun!
 [email protected]>>>>>>>>>] On Behalf Of Keith Thorne
Sent: Wednesday, December 26, 2012 7:20 AM
To: nalaka samarasinghe
Cc: [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mail!
 to:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><ma!
 ilto:[email protected]<mailto:[email protected]>><mail!
 to:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mail!
 to:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><m!
 ailto:[email protected]<mailto:[email protected]>>><mailto:tech!
 [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:tech!
 [email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:te!
 [email protected]<mailto:[email protected]>><mailto:tech-talk@aps!
 .anl.gov<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailt
[Message clipped]
Re: Error in installing asyn driver Michael Davidsaver
RE: Error in installing asyn driver Mark Rivers
Prev: EPID soft ioc slow feedback Miroslav Mihaylov
Next: Re: Error in installing asyn driver Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Error in installing asyn driver Mark Rivers
