1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error in installing asyn driver
To: [email protected]
Date: Mon, 20 May 2013 13:41:19 -0400
Looks like
https://bugs.launchpad.net/epics-base/+bug/736273
On 05/20/2013 01:24 PM, Mark Rivers wrote:
Hi Nalaka,
I am not familiar with that error, so I am including tech-talk in the reply.  I suspect perhaps the problem is that you are using a rather old version of EPICS base (3.14.10) and a new version of the gcc compiler on Ubuntu 12.04.  Is it possible for you to upgrade to base 3.14.12.3 and see if that fixes the problem?
Sent: Monday, May 20, 2013 11:05 AM
To: Mark Rivers
Hi Mark,
I am trying to install EPICS 3.14.10  on ubuntu 12.04. Is there any additional libraries we need to install ? I did all library installations done for ubuntu 10.04 LTS. But, following error appears during building process
Start:
  ake[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/libCom/O.linux-x86'
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/libCom'
make -C ./toolsComm install
make[2]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm'
make -C ./antelope install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[4]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope/O.linux-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope/O.linux-x86'
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/antelope'
make -C ./flex install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex'
make[4]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex/O.linux-x86'
make[4]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex/O.linux-x86'
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm/flex'
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/toolsComm'
make -C ./ca install
make[2]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include         ../cac.cpp
In file included from ../cac.cpp:37:0:
../cac.h:259:26: error: reference ‘mutex’ cannot be declared ‘mutable’ [-fpermissive]
../cac.h:260:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’ [-fpermissive]
In file included from ../cac.cpp:45:0:
../udpiiu.h:126:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’ [-fpermissive]
../udpiiu.h:127:26: error: reference ‘cacMutex’ cannot be declared ‘mutable’ [-fpermissive]
make[3]: *** [cac.o] Error 1
make[3]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src/ca'
make[1]: *** [ca.install] Error 2
make[1]: Leaving directory `/home/nalakasa/opt/epics/base-3.14.10/src'
make: *** [src.install] Error 2
nalakasa@ubuntu:~/opt/epics/base$
END.
Could you please help me figure out what this means ?
With Best Regards,
Nalaka
RE: Error in installing asyn driver Mark Rivers
Prev: RE: Error in installing asyn driver Mark Rivers
Next: Re: EPID soft ioc slow feedback Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Question from the dark past: CGIExport Maren Purves
