1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Communications with serial/LAN devices not using string oriented data
To: epics Techtalk <[email protected]>
Date: Thu, 23 May 2013 16:32:29 -0700
Hi All.
We have been asked to provide support for a device that communicates serially using packets of binary data. Ordinarily for such tasks I would use streamDevice, but the command protocol for this device (a CPI RF amplifier) is all binary, not strings, and even includes the requirement to byte stuff when framing characters are in the packet payload, as well as compute checksums on the packets. Any recommendations about how to approach this kind of problem? There are a LOT of different commands required to operate this device.
Thanks
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: Communications with serial/LAN devices not using string oriented data Eric Norum
Re: Communications with serial/LAN devices not using string oriented data Zenon Szalata
Re: Communications with serial/LAN devices not using string oriented data Andrew Johnson
Prev: Re: modbus driver disconnect/rewrite poll time Zenon Szalata
Next: Re: Communications with serial/LAN devices not using string oriented data Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
